Author Topic: ducky mini key cap questions  (Read 2302 times)
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« on: Wed, 11 February 2015, 00:59:43 »
Hey all. Looking for some blank white key caps to go over all my keys except the alphanumeric ones.
Any suggestions on the type of key caps I should be looking for?
  • Formerly Deeptek
Re: ducky mini key cap questions
« Reply #1 on: Wed, 11 February 2015, 10:06:38 »
Or any keycaps that will work.. :)
Offline KatzenKinder
« Reply #2 on: Wed, 11 February 2015, 12:55:03 »
If you're not super worried about thickness, there's this set
http://www.geekkeys.com/blank-pbt-104-keyset/
Pretty cheap, and PBT too so nice feels. It's all standard ANSI so it will fit ducky mini perfectly.
  • Formerly Deeptek
« Reply #3 on: Wed, 11 February 2015, 13:27:31 »
Thanks. So any PBT caps will work?
« Reply #4 on: Wed, 11 February 2015, 14:23:27 »
Uhhh not necessarily any, but any set that advertises itself as an ANSI set (probably). Ok any ANSI set with 1.25u mods.
