Author Topic: FN key has stopped working on poker 2  (Read 2058 times)
Offline snipars
« on: Thu, 12 February 2015, 06:55:09 »
Hello, i was toggling the backlight on and off on my new poker 2 and the FN key seems to have stopped working, i've remapped FN to the left win key using the dip switch and that works.
i've tried binding something else to that key but it wasn't recognised, so it seems the switch isn't working, any ideas how i can fix this?
the key presses down normally and feels fine
Duck Octagon + Gateron Black |HHKB Pro 2 | Poker 2 + Vintage Black + Tex case | Unicomp Ultra Classic | WASD V2 |
Offline MAR82
  • Keyboard Addict
Re: FN key has stopped working on poker 2
« Reply #1 on: Thu, 12 February 2015, 07:49:39 »
I'm not sure if it will fix your issue. But the first thing I would try is doing a reset, you can find how to do that on page 3 of the manual https://adprice.fedorapeople.org/poker2_manual.pdf
Offline snipars
« Reply #2 on: Thu, 12 February 2015, 07:52:46 »
i already tried that :(
nevermind, i took it apart and the previous seller only had it screwed in with 4 screws, i put all 6 in and it works fine now, how odd
« Last Edit: Thu, 12 February 2015, 08:01:54 by snipars »
