Author Topic: G80-11802LPAJA: Before and After Cleaning  (Read 11604 times)
Offline infiniti
  • I <3 KB
  • Bob was here
« on: Thu, 12 February 2015, 09:11:31 »
I have Sturmfrau's G80-11802LPAJA for cleaning and retr0brighting since I have too much free time and love all things keyboard.
He picked this up when his office did some space clearing.
The keyboard works but the Pause Break is acting weird.  It actuates but doesn't stay actuated when the key is held down.  Average time is 7-8ms using EK's Switch Hitter.  It might need a little cleaning or the soldering needs to be reflowed.
I can't test the trackball right now since my mobo only has one PS2 port and i think both need to be plugged in for it to work.
Anyway, here are some before pictures.
This is why you shouldn't wrap cables around a keyboard.
Cherry MX Browns
Tactile Gray for the Space Bar
Left to right: GMK ABS Doubleshot Red Esc (Row E)  ||  GMK PBT Lasered (Row E)  ||  SP DCS Doubleshot Red Esc (Row 1)
After scrubbing with soap and water...
After retr0brighting!
Reassembly!
Bonus pic!
Slapped on a GMK red Esc and some RGB Modifiers!  I didn't have a green 1x shift so I used the Fn. :p
~ fin ~
Edit: Reuploaded pictures to Imgur.  RIP Dropbox Public Folder.
« Last Edit: Sat, 17 June 2017, 11:34:27 by infiniti »
Offline Sturmfrau
Re: G80-11802LPAJA: Before and After Cleaning
« Reply #1 on: Thu, 12 February 2015, 19:24:55 »
So excited for the after pics :D
HHKB Pro 2 Black (Blank) | HHKB Pro 2 White (Blank)
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #2 on: Thu, 12 February 2015, 19:34:45 »
I'm jelly of the Japanese caps.
GON NerD TKL DTA Edition
Offline Zeal
    • Zeal Generation Inc.
« Reply #3 on: Thu, 12 February 2015, 19:52:09 »
As a right thumb spacebar presser, that 3u spacebar would make me cry. :'(
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #4 on: Sat, 14 February 2015, 06:07:04 »
Same here...when testing it, I kept hitting the below N and m.
Oh yeah, uploaded the pics of the inside and a comparison of the key caps.
Tomorrow (Sunday) is surface cleaning the case with soap, a toothbrush, and a sponge.  Then hopefully I can start retr0brighting first thing on Monday morning under the sun.
Offline Hzza
« Reply #5 on: Sat, 14 February 2015, 15:05:20 »
That is a cool board, are you going to do anything funky with it or just get it cleaned up?
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #6 on: Sat, 14 February 2015, 21:59:22 »
No, nothing funky since it's not mine.
I offered to clean it up for Sturmfrau as an excuse to get my paws on the keyboard and take photos to document it. :))
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #7 on: Tue, 17 February 2015, 06:31:25 »
Done!
Updated the OP with more pictures! :thumb:
« Reply #8 on: Tue, 17 February 2015, 06:34:18 »
Nice job. I'd love to know more about how you retrobrited the case.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #9 on: Tue, 17 February 2015, 06:55:47 »
nice~~~~
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #10 on: Tue, 17 February 2015, 07:34:06 »
Thanks man!
So...on retr0briting, I only have one pic since I forgot to take pictures so please bear with all the text. :p
I decided to soak both the upper and lower halves of the case in a single bath to ensure that they would lighten to the same extent and match.
I used:
  • A large plastic bin
  • 2 liters of 10 volume / V10 / 3% hydrogen peroxide
  • 500ml of 20 volume / V20 / 6% hydrogen peroxide
  • 1 scoop OxiClean
  • Enough tap water to submerge the cases in the bin (estimated at 4-6 liters)
  • three drinking glasses to hold the cases down
I put the case in the bin, weighed them down with the glasses and poured in the hydrogen peroxide.  Added tap water until the cases were submerged.  Added the OxiClean and swished the mixture back and forth in the bin.  THE MIXTURE WILL BUBBLE AND TURN YELLOW.  It looks like watered down mountain dew.
There wasn't enough direct sunlight outside so I started by an upstairs window.
Here's a picture:
Yeah, I tried to retr0bite an iPhone case...it didn't work.
I checked it every twenty minutes and mixed the solution.  After forty minutes I found a big enough spot of direct sunlight outside and took the bin outside...aaaaand I promptly forgot my phone and camera.
Outside in the direct sunlight it started to bubble A LOT more and become MORE yellow.  Forty more minutes in the tropical sun and it was done. :thumb:
« Last Edit: Sat, 17 June 2017, 11:35:29 by infiniti »
Offline Dreamre
    • kbdlife
« Reply #11 on: Tue, 17 February 2015, 17:24:17 »
Love your posts! Thanks for sharing :D.
Offline rainb1ood
  • so pretty so plastic
« Reply #12 on: Tue, 17 February 2015, 17:36:06 »
You did an amazing job on this! It looked so new now
Offline Sturmfrau
« Reply #13 on: Tue, 17 February 2015, 21:31:53 »
I get a bonus RGB Keys!? WOW! ahahaha Thanks man. Awesome work!
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #14 on: Tue, 17 February 2015, 22:41:04 »
Nope.  They're just there for photo purposes.  :p
Offline Sturmfrau
« Reply #15 on: Tue, 17 February 2015, 23:24:29 »
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
