Author Topic: Poker II dead keys  (Read 1407 times)
Offline m1hka
Poker II dead keys
« on: Fri, 13 February 2015, 00:16:22 »
Hello,
I've made Poker II LED mod yesterday. All lights are okay but "Q", "1", "ESC" and "TAB" keys are dead. What could be wrong? Any advice/thoughts would be helpful.
Sorry about photo quality.
Offline m1hka
Re: Poker II dead keys
« Reply #1 on: Sat, 14 February 2015, 02:42:30 »
Better photo in attachment. Please help somebody.
Offline Oobly
« Reply #2 on: Sat, 14 February 2015, 03:41:21 »
The tracks going past the "A" switch and "Z" switch to the controller chip look like they could be damaged. Also, it looks like you may have some loose pieces of solder "dust" in various spots, check that the controller chip pins are clear of any such debris, as they're quite close together and could easily be bridged by a small piece of solder.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline m1hka
« Reply #3 on: Sat, 14 February 2015, 05:21:38 »
Controller is perfectly fine. "A" and "Z" are working.
Offline m1hka
« Reply #4 on: Sat, 14 February 2015, 05:44:19 »
You were right. It's the track near "A" switch. Any way to fix it? I'm newbie :(
