Author Topic: Ducky Shine 3, help me please :/  (Read 2478 times)
Offline Fullsa
« on: Fri, 13 February 2015, 11:14:17 »
Hello, this is my first msg in this community.
I have got a ducky shine 3, unfortunately i broke the right feet of my keyboard.
I would ask you all if you could help me to find a reseller where to find this item, because i really don't know how to find this.
Please help me  :(
Re: Ducky Shine 3, help me please :/
« Reply #1 on: Sat, 14 February 2015, 18:37:11 »
Welcome to Geekhack!
Apart from suggesting you try using the keyboard flat (I did, and now I use all my keyboards flat), I don't know whether Filco feet are the same.  Maybe someone with both keyboards could confirm.
http://www.keyboardco.com/product/filco-legs-one-pair.asp
This post seems to vaguely suggest that Filco legs will work on a Ducky.
Otherwise you could try contacting Ducky directly.  If the keyboard is still under warranty they might ship replacement parts.  Otherwise they might sell you replacement legs.  Might - I don't recall hearing of anyone who tried contacting them for legs.
Offline jackalope
  • Now with 20% more soul.
« Reply #2 on: Sat, 14 February 2015, 23:13:07 »
They appear to be the same size and design. Little nervous about breaking them or i would swap to check, but included pictures tho to compare. Hope it helps.
Copper color is the Filco mj2, black is the Ducky Shine 3
90793-090791-1
« Last Edit: Sat, 14 February 2015, 23:15:07 by jackalope »
eh o well
Offline dukkyt
« Reply #3 on: Sun, 15 February 2015, 00:11:16 »
Ducky's are, well... difficult. They are incredibly rare. In fact, it's unlikely that the popular sites such as mechanicalkeyboards or ncix us will be restocking shine 3's ever again. So if you're looking to buy a new board, good luck to you. Not saying it's impossible, just difficult, and potentially pricey.
As far as the feet... try the filco ones mentioned above... it can't hurt it anymore, right? Or try using without the feet. I personally use my ducky without the feet, but it's just my preference.
Offline Fullsa
« Reply #4 on: Sun, 15 February 2015, 06:39:11 »
Thank you guys for your answers!
At moment i'm using my keyboard without feet and is good, but i want to restore the right feet. I will buy the filco's feet and i will let you know
many thank you again ^^
