Author Topic: Unlit LED keys on Mac (e.g. scroll lock) SOLVED  (Read 6931 times)
Offline DamienG
    • DamienG
« on: Sun, 15 February 2015, 06:07:12 »
So those of us with backlit keyboards have been a little miffed that the modifier leds are unlit unless we toggle them on. This has two problems:
1. The Mac has no scroll-lock feature in the OS so you can't turn it on
2. Nobody wants to leave caps-lock on as you can't type without shouting
There is now a solution - http://github.com/damieng/setledsmac
Simple download the binary from the release page and put it somewhere on your machine then from the terminal run it with +scroll +num +caps, e.g.
Code: [Select]
./setledsmac +scroll +num +caps
If you only want to set the LEDs on a specific keyboard then use the -name option with a wildcard, e.g.
Code: [Select]
./setledsmac +scroll -name "*Ducky*"
If you're worried about running a binary from somebody you barely know just download or git checkout the project and load it into XCode.
Requires 10.5 or better, 32-bit or 64-bit are supported.
Update: I should clarify that this turns the LEDs on without activating the lock itself. So you can type with your caps lock light on but still in normal case.
[)amien
« Last Edit: Sun, 15 February 2015, 20:58:59 by DamienG »
Offline wyatt8740
  • Machine code enthusiast
Re: Unlit LED keys on Mac (e.g. scroll lock) SOLVED
« Reply #1 on: Sun, 15 February 2015, 15:20:16 »
This is cool. I rarely (about once every two months) boot into OS X on my iMac (I use Debian Linux), but I had to boot to it to try this. :D
I don't usually collect things, but when I do, they're from the 70's, 80's, and 90's. My typing speed: 79 WPM
IBM Model M 1386303, 1987 / IBM Model M 1391401, 1993 / IBM Model M 59G7980, 1993 / Unicomp "Mini M" UT40E7A (modded), 2021 / Dell AT101W, 1994 (Black Alps) / Apple Extended Keyboard (Orange Alps), 1987 / Sun Type 5, unknown year (Rubber Dome)
Offline DamienG
    • DamienG
« Reply #2 on: Sun, 15 February 2015, 20:59:43 »
Glad you like it Wyatt.
Obviously you have setleds on Linux already - I used the exact same command line syntax although because OS X and Linux are so different I couldn't use any of the code.
[)amien
