Author Topic: Thoughts on the Digilog Alu case for Realforce  (Read 2490 times)
Offline Harbec
« on: Sun, 15 February 2015, 20:58:46 »
Looking into buying one. Anyone have some input in regards to the build quality and overall opinions on the case?
Offline FrostyToast
  • Litshoard
Re: Thoughts on the Digilog Alu case for Realforce
« Reply #1 on: Sun, 15 February 2015, 21:00:41 »
Thing is heavy. ~6 pounds.
Build quality is pretty acceptable.
The acoustics get worse IMO.
The daughterboard is a bit odd and there are reports of it not working properly, however that can be resolved.
The extra USB slots are cool.
Quote from: elton5354
Offline Harbec
« Reply #2 on: Sun, 15 February 2015, 21:19:41 »
Could you describe the acoustics? Can't find a sound comparison.
Offline flaming_june
« Reply #3 on: Sun, 15 February 2015, 21:21:04 »
So what IS the better/best cases for realforce tkl?
Offline Chromako
  • Worshipper of the Topre and IBM Gods
« Reply #4 on: Sun, 15 February 2015, 22:47:16 »
I also agree- the acoustics get worse, but the difference is quite minor, IMHO. Slightly less "thock." It "feels" more solid, but that could be psychological.
The two halves of the case are held together by four screws. On mine, the screw thread on one of the holes wasn't deep enough for the provided screws, which meant that I had to trim about 3mm off the tip of one of the provided screws with a dremel to make it fit properly. Ugh. (That's the sound of me being annoyed)
Build quality is quite nice, other than that one problem I mentioned. It feels very solid, and looks classy. The anodising is also well done. The aluminum in the case is actually connected to the USB cable's shield (I checked continuity with a multimeter) which indicates some thought above "let's make it look shiny so we can sell it to people" was put into its design. I appreciate that.
I had no problems with the daughterboard on my unit, but I have heard that some people got defective ones. Hopefully they fixed the issue in one the ones they are selling now.
I'm unaware of any other metal Realforce TKL cases being sold right now.
« Last Edit: Sun, 15 February 2015, 22:50:41 by Chromako »
Thou Shalt Not Violate Causality, Nor Shalt Thou Invert Thy Spacebar.
Offline Harbec
« Reply #5 on: Sun, 15 February 2015, 23:11:53 »
Any particular vendors you would recommend?
Offline intelli78
« Reply #6 on: Sun, 15 February 2015, 23:26:00 »
Mine is for sale again, I sent you a PM. I have the fixed USB board btw.
Offline FrostyToast
  • Litshoard
« Reply #7 on: Sun, 15 February 2015, 23:26:56 »
The plastic case give the thock of Topre a much more "open" feel.
The Aluminum for some reason sort of "dampens" that thock.
Offline Chromako
« Reply #8 on: Mon, 16 February 2015, 22:43:56 »
Yes. This. It turns from a "thock thock" to more of a "pitter patter," if that made any sense at all? It's like the plastic case has some pleasant resonance that the heavy, thick aluminum doesn't have. I don't happen to mind the change, for that matter.
