Author Topic: Fried Rosewill RK-9000RE with static electricity. Need new controller?  (Read 1989 times)
Offline lupohki
It's been extra dry around here and i've been zapping things left and right.  My beloved RK-9000RE took a zap that took out the "`1qaz" keys.  Everything else seems to work.  Is this a symptom of just needing a new controller or is something on the main pcb fried?  I saw the thread where someone sold custom replacement controllers.  I had already rescued the RK-9000RE from a loose usb port by hard wiring the cable and I would like to save her again. :)
Re: Fried Rosewill RK-9000RE with static electricity. Need new controller?
« Reply #1 on: Mon, 16 February 2015, 14:58:46 »
Yes, a Black Petal should fix that for you. :)
Offline daerid
    • Rossipedia
« Reply #2 on: Mon, 16 February 2015, 16:48:43 »
I actually did that to my CODE 104. Luckily WASD covered it under warranty and I got a replacement. Friggin LOVE those guys.
« Reply #3 on: Mon, 16 February 2015, 16:52:00 »
Yeah, this is a perfect opportunity to make the upgrade.  Black Petal is great.
Offline radish
« Reply #4 on: Tue, 17 February 2015, 16:24:11 »
i have a rose will controller from that very kb. if you need it send me a pm.
LZ CP
Offline lupohki
« Reply #5 on: Tue, 17 February 2015, 21:25:00 »
Thanks, sent you a PM
