Author Topic: Model M Key Caps  (Read 2214 times)
Offline Evrycard
Model M Key Caps
« on: Tue, 17 February 2015, 00:36:28 »
Where can I get these key caps?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Model M Key Caps
« Reply #1 on: Tue, 17 February 2015, 00:39:28 »
http://www.pckeyboard.com/page/Buttons/PRGB
But they will be black legends and not white
Offline Evrycard
« Reply #2 on: Tue, 17 February 2015, 00:53:37 »
Will the Unicomp fit the Model M?
Offline Rotaku
  • Too Based
« Reply #3 on: Tue, 17 February 2015, 00:55:46 »
Unicomp keyboards are model m's silly :) Plus A buckling spring keycap fits any buckling spring keyboards
Not toooo active on GH anymore, if you need me, shoot me a PM on Reddit! /u/IchibanXD
Offline Melvang
« Reply #4 on: Tue, 17 February 2015, 00:56:04 »
Yes, all buckling springs keyboards of IBM style are interchangeable aside from possible different stabilizer setups between M's, and different versions of the F.  I am using M caps on my F AT right now.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #5 on: Wed, 18 February 2015, 07:12:31 »
Does not fit the 105 key chassis
