Author Topic: AT Model F  (Read 2902 times)
Offline engicoder
AT Model F
« on: Tue, 17 February 2015, 08:30:36 »
http://www.ebay.com/itm/371261088269
Healthy starting bid, but with some modding, closest you'll get to an ANSI model F.
Offline 1391406
Re: AT Model F
« Reply #1 on: Tue, 17 February 2015, 09:04:24 »
If I were interested, I'd have wanted the CTRL keys modded in next to the space bar.
Offline JPG
  • Model F is my new passion!
Re: AT Model F
« Reply #2 on: Tue, 17 February 2015, 09:12:40 »
While desirable, I got used to having a ctrl on the left and alt on the right of spacebar as my only options. I mostly use the alt for the @ key while I use ctrl for the classic ctrl-a, ctrl-c, ctrl-v (the core skill of a programmer :p).
Re: AT Model F
« Reply #3 on: Tue, 17 February 2015, 09:14:53 »
Did you guys see Muirium's awesome setup over on DT?
- D Trump 2026-10-24
Offline JPG
Re: AT Model F
« Reply #4 on: Tue, 17 February 2015, 09:15:33 »
Nope, you have a link?
Offline engicoder
Re: AT Model F
« Reply #5 on: Tue, 17 February 2015, 09:21:56 »
This is what I was thinking of:
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: AT Model F
« Reply #6 on: Tue, 17 February 2015, 09:38:20 »
The only hard part is modifying the plate to accept the space bar barrel as it is full width and has the barrels for the stabilizer wire built in.  The PCB already has the pads and xwhatsit utility works just fine with it.  I didn't do the space bar mod on my AT, but I have tweaked the numpad area to a straight 4x5 matrix with numpad and dedicated arrow keys.
In case anyone is curious.
Offline Touch_It
Re: AT Model F
« Reply #7 on: Tue, 17 February 2015, 12:30:52 »
Maybe someday I will own one.  Model F's are like Pokemon.  Gotta catch `em all.
Re: AT Model F
« Reply #8 on: Tue, 17 February 2015, 12:32:15 »
I'll trade you one for your 107. :))
Offline Touch_It
Re: AT Model F
« Reply #9 on: Tue, 17 February 2015, 12:33:50 »
:D. I think I'll pass for now.
Offline 1391406
Re: AT Model F
« Reply #10 on: Wed, 18 February 2015, 08:49:30 »
Exactly.
Re: AT Model F
« Reply #11 on: Thu, 19 February 2015, 20:00:21 »
When I get my nerve up and have some time, I will be adding "Alt" keys to my AT.
