Author Topic: HHKB Mac: CTRL vs CMD vs FN  (Read 11336 times)
Offline TopreFan333
« on: Tue, 17 February 2015, 13:09:41 »
What about switching the FN and CTRL keys on an HHKB for Mac use?
Hear me out:
-- one of the main features of the HHKB layout is that the CTRL key is promoted to the left of the A. This is probably great on a PC, where CTRL is pretty much analogous to CMD on a Mac, and used very frequently. But on a Mac, CTRL is much less frequently used in most applications. It comes up now and then, but CMD is your primary command key.
-- the FN key is all-important on a HHKB because of that FN layer, but it's in a somewhat less-easily accessible spot than the CTRL key. I know you get used to it, but still, it's a smaller key and it's way down at the bottom
So now I'm wondering about swapping the two. I'm early in my HHKB learning curve so I could still make the switch. Any other Mac HHKB users out there have thoughts or have maybe made this switch?
A second idea would be to switch the CTRL key and CMD key, in effect "promoting" the CMD key as the PC-centric HHKB layout does now...
Offline Sygaldry
  • Edema Ruh
Re: HHKB Mac: CTRL vs CMD vs FN
« Reply #1 on: Tue, 17 February 2015, 13:12:58 »
Hear me out:
On my Mac I have my Control key set to CMD to sort of emulate its behavior on Windows. The only shortcoming is when I'm working in Terminal and need to actually use the Control key as opposed to the CMD key. Not a huge problem though, considering the benefits I get from having CMD in the CapsLock position for everyday browsing and word processing and what not.
null
Offline saturnotaku
« Reply #2 on: Tue, 17 February 2015, 13:26:07 »
Hear me out:
The keyboard preference pane in OS X gives you the option to swap command, control, alt, and caps lock among each other as you see fit. It's particularly handy for mechanical keyboards that don't have dip switches to alter the layout in hardware.
I like where the Fn key is because all of the functions I use with it (arrow keys, pg up, pg down, etc) can be done with one hand.
Offline TopreFan333
« Reply #3 on: Tue, 17 February 2015, 14:07:47 »
Interesting. Do you have both the command keys on either side of the spacebar set to CTRL? Did you do this through a DIP switch or through software?
Offline TopreFan333
« Reply #4 on: Tue, 17 February 2015, 14:14:13 »
That's a good point. I thought of that too. Might be smarter to not mess with the FN!
Offline Sygaldry
  • Edema Ruh
« Reply #5 on: Tue, 17 February 2015, 14:16:23 »
I used both the dip switch and the Mac keyboard setting.
Makes it so that no matter what computer I'm using, I have about the same functionality.
null
