Author Topic: Mechanical or not?  (Read 1610 times)
Offline pnutster
Mechanical or not?
« on: Tue, 17 February 2015, 18:26:42 »
http://www.ebay.com/itm/101-Key-AT-Type-PC-Keyboard-KeyPad-97C002/161285146576?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D777000%26algo%3DABA.MBE%26ao%3D1%26asc%3D29172%26meid%3Deda5f44d1710404d844d7b513d2657dd%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D161517485843
Anyone knows more about this?
hmmmppfff.. I guess the answer is already given:
It uses membrane technology to protect keys from dust, liquids, see pic #4 for the type of key switch slider.
« Last Edit: Tue, 17 February 2015, 18:30:13 by pnutster »
Kinesis Advantage
Logitech Cordless Trackman FX Optical Trackball
Apple TrackPad
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Mechanical or not?
« Reply #1 on: Tue, 17 February 2015, 18:43:21 »
Looks very much like a dome with slider design, possibly BTC?
  • Live long and prosper
« Reply #2 on: Tue, 17 February 2015, 19:03:21 »
MX compatible caps though...
tp thread is tp thread
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Tue, 17 February 2015, 19:51:57 »
I know, that's why. BTC dome with slider IS MX compatible.
http://deskthority.net/wiki/BTC_dome_with_slider
« Reply #4 on: Tue, 17 February 2015, 23:13:11 »
BTC keyboards often have a 1.25 Esc key and a metal bottom, and the switch does not look quite like it.
The FCC ID lookup reveals "Dih Shin Industries Co Ltd" in Taipei, Taiwan. 1990. but that doesn't tell me anything.
There are lots of variants of MX-compatible sliders over domes.
