Author Topic: Leopold FC660m key rollover  (Read 2637 times)
Offline DuckMyDucky
« on: Wed, 18 February 2015, 02:00:45 »
I'm sort of looking into the leopold fc600m, but in the description it says no key rollover while using usb. I also recall reading somewhere that normal key combinations like ctrl+shift+esc doesn't work. Is this correct?
Offline pr1me
Re: Leopold FC660m key rollover
« Reply #1 on: Wed, 18 February 2015, 14:09:08 »
6kro with USB and Nkro with ps/2
Offline DuckMyDucky
« Reply #2 on: Wed, 18 February 2015, 14:52:07 »
How can it be 6kro over usb if ctrl+shift+esc doesn't work?
Either way I guess I can remove this keyboard from list of potential keyboards then :p
