Author Topic: [GB] Gateron Switch (CLOSED)  (Read 1111684 times)
Offline Thechemist
Re: [GB] Gateron Switches (Taking extra orders)
« Reply #1350 on: Wed, 08 April 2015, 23:40:39 »
I can give up my blues in exchange for blacks, if anyone's interested.
Btw, do you guys have any idea whether the clear tops are as smooth as the stock tops?
I can't tell if the clear tops are smoother but they sure fit more snug than the stock clear tops. The stock tops feel like cherry tops while the clear tops have a tighter fit to the bottom of the switch. The actual movement of the stem in the top I haven't tested but I prefer the clear switch tops to the stock Gateron tops.
« Last Edit: Wed, 08 April 2015, 23:42:23 by Thechemist »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #1351 on: Thu, 09 April 2015, 00:58:59 »
Shaddoved: you got the switches in your house now?
Offline Magna224
« Reply #1352 on: Thu, 09 April 2015, 04:18:29 »
I might be interested in like 80 of the 35g linears if you have some left to add to my order.
Offline wlhlm
« Reply #1353 on: Thu, 09 April 2015, 04:26:03 »
updated the OP, sorry about that
We are outta clears as well, I need to maintain a small buffer for accidents.
Just an FYI: Shadovved told me, that there are still 2000-3000 clear switch tops left - so you still can happily order some of those ;)
And yes, we still have switch tops.....only switch tops left.
Offline Mooksie
« Reply #1354 on: Thu, 09 April 2015, 11:45:11 »
Any update on the ETA?
we use up all the cupholders during our furious love making sessions
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #1355 on: Thu, 09 April 2015, 11:48:10 »
Gotta fill em with Gaterons :)
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #1356 on: Thu, 09 April 2015, 17:43:34 »
They just shipped out from China......slight delay expected, but should be able to send everything out by end of this month.
Offline Gloomy Moonie
« Reply #1357 on: Thu, 09 April 2015, 17:47:27 »
Where are you sending them from? US?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #1358 on: Thu, 09 April 2015, 17:49:13 »
Singapore
Offline ideus
  • Björkö.
« Reply #1359 on: Thu, 09 April 2015, 22:17:21 »
What plates are these? You made them?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #1360 on: Thu, 09 April 2015, 22:31:57 »
ISO 60%. I got them cut in China.
Offline daviswalkers
  • HHKB Amature 2
    • Graphic Design Portfolio
« Reply #1361 on: Sun, 12 April 2015, 01:21:00 »
Am I missing something, the whole "clear vs stock tops" I was under the impression if I ordered say, 100xClear Switches that I would be getting 100xGateron Clear Switches with the Clear top? Or do I need to order the switches and the tops?
Compact-SQ |          VE.A
 65g Zealios    |      78g Zealios
Offline wlhlm
« Reply #1362 on: Sun, 12 April 2015, 01:56:06 »
Yes, you have to order them separately. The switches sold in this group buy are translucent, but milky. The extra switch tops are more clear.
  • HHKB Amature 2
« Reply #1363 on: Sun, 12 April 2015, 02:33:31 »
Good to know -_- glad I caught this now
Compact-SQ |          VE.A
Offline awhitedev
« Reply #1364 on: Sun, 12 April 2015, 12:00:16 »
Sounds great Shadovved!  Keep us posted :D
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #1365 on: Sun, 12 April 2015, 12:31:53 »
I forgot what I ordered o.o anyway to see what I did order?
Offline duckness
« Reply #1366 on: Sun, 12 April 2015, 12:34:10 »
check your Paypal invoice?
Offline Bromono
  • Wanabe Cicerone
« Reply #1367 on: Sun, 12 April 2015, 12:43:41 »
nvm found it. 70 black :)
« Last Edit: Sun, 12 April 2015, 12:45:15 by Bromono »
Offline Shadovved
« Reply #1368 on: Mon, 13 April 2015, 06:50:21 »
I finally got my PBT set samples......from my IC thread.
imsto, SP, GMK, new PBT set.
Imsto vs new PBT & GMK
Grey comparison to GH gold pack set
Full set & spacebar
Colours (dark grey, light grey, beige, cool white, blinded by white.......dont use a full set of this)
« Last Edit: Mon, 13 April 2015, 07:19:37 by Shadovved »
« Reply #1369 on: Mon, 13 April 2015, 07:12:40 »
Those look very good.  I must have missed that IC
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #1370 on: Mon, 13 April 2015, 07:16:20 »
Same here
Offline Shadovved
« Reply #1371 on: Mon, 13 April 2015, 07:20:27 »
Same here
It was together with my switch top GB, but due to lacking interest the GB fell through.
I'm intending to run it again after I settle the Gateron, probably June?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #1372 on: Mon, 13 April 2015, 07:21:07 »
Same here
Interested :)
Offline Ngt
« Reply #1373 on: Mon, 13 April 2015, 17:56:47 »
I remember taking part of it. I registered for a set. I was sad that it was canceled ... :'(. We'll see later then.
« Reply #1374 on: Mon, 13 April 2015, 18:31:58 »
Sign me up for a set of white caps or whatever the second cap from the right is.
Offline rsac
« Reply #1375 on: Tue, 14 April 2015, 09:27:00 »
It's rather amusing to me that black stems are the least valued of the MX switches and yet apparently the most valued of the gateron switches.  MX black has typically been the slowest seller, and that Pok3r GB only offered red, blue, brown, and clear, for example.  I wonder if the glowing reviews from linear switch lovers have kicked up a little #hype storm.
Those Gateron blacks are quite unique, not being as stiff as MX Blacks, but stiffer than MX Reds. They are supposedly smoother than MX ones too.
Offline Ngt
« Reply #1376 on: Tue, 14 April 2015, 11:50:25 »
They definitely are smoother.
« Reply #1377 on: Tue, 14 April 2015, 13:35:12 »
This calls for a double-blind study
Offline ideus
  • Björkö.
« Reply #1378 on: Tue, 14 April 2015, 13:58:43 »
Full set & spacebar
That space bar with multiple stems looks nice.
Offline Ngt
« Reply #1379 on: Tue, 14 April 2015, 16:56:59 »
I have a switch tester with a stock MX black and a gBlack side by side. I'll try to make a blind test when I'll find someone to help with it. :)
Offline FoC_Tow
  • Brokehlicious
« Reply #1380 on: Tue, 14 April 2015, 19:35:56 »
Woah, seems like I missed out on this IC as well! Ö_Ö
That far right 'blinded by white' looks super interesting!
It somehow looks very smooth or soft, almost Jelly POM like!
Is it slightly translucent or just very glossy? Why not use a full set of these, will you go blind? xD
Offline Shadovved
« Reply #1381 on: Tue, 14 April 2015, 22:03:58 »
Woah, seems like I missed out on this IC as well! �_�
It's the same PBT material, but it's just super glaring when I look at a ziplock bag of it.
I'll probably only run the GB in the first all 5 colours if the glaring white receives enough attention, or else I'll just combine both whites to the normal one and run 4 colours.
« Reply #1382 on: Tue, 14 April 2015, 22:09:13 »
Blanks only?
Offline Shadovved
« Reply #1383 on: Wed, 15 April 2015, 01:56:32 »
Blanks only?
Blanks first. To build up the relationship before I go into dye-subs.
Offline Shadovved
« Reply #1384 on: Wed, 15 April 2015, 02:06:08 »
Oh, and I just received news the Gateron stuff will be arriving tomorrow.
Should be able to pickup by Friday :))
Offline azhdar
  • Praise the AZERTY god
« Reply #1385 on: Wed, 15 April 2015, 02:16:36 »
yeeeee
You know we will need pictures of this massive batch of switches right?!
Azerty Propagandiste
Offline Shadovved
« Reply #1386 on: Wed, 15 April 2015, 02:21:45 »
yeeeee
I'll take pictures when I visit the warehouse building, and when I get back :D
Offline azhdar
« Reply #1387 on: Wed, 15 April 2015, 02:25:45 »
Fantastic.
Also a though I had the other day, if you're in direct contact with gateron, you should suggest them to do ergo-clear like switches :)
Offline asdfjkl36
  • blue shirt guy
« Reply #1388 on: Wed, 15 April 2015, 02:32:07 »
Sweeeet
Can't want for the next update
Thanks for keeping us in the loop :)
Offline Ngt
« Reply #1389 on: Wed, 15 April 2015, 02:45:22 »
yeeeee
Hehe looking forward to these funny pictures!
Offline joey
« Reply #1390 on: Wed, 15 April 2015, 03:29:49 »
Fantastic.
yeaaaaa!
Offline ideus
  • Björkö.
« Reply #1391 on: Wed, 15 April 2015, 07:34:36 »
We want to see a bunch of boxes, a pile of switches, and small packages arriving at our doors.
Offline Shadovved
« Reply #1392 on: Wed, 15 April 2015, 07:39:01 »
Soon
Offline Mooksie
« Reply #1393 on: Wed, 15 April 2015, 07:48:47 »
Excite!
Offline Red_dino
  • #FREEGUCCI
« Reply #1394 on: Wed, 15 April 2015, 15:55:01 »
Can't wait to get my blacks!  ;D
Just out of curiosity, roughly how long does it take to ship from Singapore to the U.S.?
I don't sleep, because sleep is the cousin of death.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #1395 on: Wed, 15 April 2015, 16:52:49 »
Yes, i can't seem to find it online.
Offline azhdar
« Reply #1396 on: Wed, 15 April 2015, 16:57:31 »
The shipping time is probably not really revelant here since most of the waiting time will be because of the time it will take to shadovved to sort out, and package more than 100.000 switches.
But I've had packages taking less than a week to do ASIA=>Europe, so should be about the same shipping time for murica.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #1397 on: Wed, 15 April 2015, 16:58:46 »
Offline Red_dino
  • #FREEGUCCI
« Reply #1398 on: Wed, 15 April 2015, 17:06:28 »
That's a good point, we definitely owe Shadovved a big thanks for dealing with all of those switches for us! :thumb: I guess I'll just have to be patient.
Offline retrochick
  • goodbye my wallet
« Reply #1399 on: Wed, 15 April 2015, 17:47:47 »
It usually takes around a week or so, based on previous buying experiences.
