Author Topic: Filco Majestouch 2 chord replace  (Read 2052 times)
Offline cdayo
« on: Wed, 18 February 2015, 14:45:23 »
Hey all,
Just signed up so I could get some answers on a Filco I picked up!
The keyboard was cheap as it came with no USB cord. I've done electronic fixes before so I'm thinking it's easy enough...!
Needless to say I'm posting here with a few questions about sourcing the parts I need.
I am looking for a 5 pin socket with 2mm pitch which can fit into this badboy - the white receptacle at the top
I know that the piece can be found here http://i.imgur.com/oG5Ts.png...the only problem with that is I would have to pay $20 to have 1(!!!!!!!) shipped to my house. Not a financially friendly option
I am wondering if anyone could offer any advice in where I could source these pieces without paying a lot for shipping, or possible even locally (even through surplus). I was thinking/wondering if anyone knows of common electric components that would have a receptacle like this...maybe something like a computer fan? Or even if these pieces are common in other keyboards? I am located in Toronto.
Without this piece I could de-solder the receptacle from the board but that is really a last resort.
Thanks for the help!
C
Offline padath
Re: Filco Majestouch 2 chord replace
« Reply #1 on: Wed, 18 February 2015, 14:52:02 »
Welcome to GH
You can get ready made cables from Pexon (in the UK) for the Filco MJ2.
« Reply #2 on: Wed, 18 February 2015, 14:53:47 »
Are you determined to fix it yourself? If you are that's fine but I just wanted to point out that there are cable vendors which will make you a cable specifically with the Filco end. Zeal is located in Canada so perhaps that would help you. If you wanted to go DIY, I'd PM tjcaustin or Zeal and just ask them for some help :).
Welcome to Geekhack!
Offline cdayo
« Reply #3 on: Wed, 18 February 2015, 21:55:33 »
Thanks to both of you.
I sent out some PMs and got a little info, I might just have to go with Pexon!
Offline Oobly
« Reply #4 on: Thu, 19 February 2015, 01:34:45 »
His cables are top notch, truly well made.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
