Author Topic: Dutch IBM model m?  (Read 2942 times)
Offline gergo2007
Dutch IBM model m?
« on: Thu, 19 February 2015, 15:17:49 »
Hey guys
I just got hand on what i think is an ibm model m with dutch layout and I thought I would share some pictures (i got the keys off for cleaning)
Also the sticker with the serial number and other info is off, but on the back there is a sticker (see last picture).
Also is this one a rubber dome one?
Re: Dutch IBM model m?
« Reply #1 on: Thu, 19 February 2015, 15:20:51 »
It's definitely a buckling spring.
With all the caps removed, I can't tell what layout it is.
Offline gergo2007
« Reply #2 on: Thu, 19 February 2015, 15:26:52 »
On wikipedia i found this:
Dutch QWERTY layout, 1378705, EC1391461
And on wiki it shosw that it has Dome switches (and no detachable caps or cable, but what i have has detachable ones)
Also on the back of the keyboard there is a sticker that shows that it was bought from kraan bouwcomputing, rotterdam
« Reply #3 on: Thu, 19 February 2015, 15:29:46 »
I promise you that's not a rubber dome board. You can see the spring part of the buckling spring clearly in your pictures.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Thu, 19 February 2015, 17:47:11 »
From a picture of the Dutch layout it definitely looks like that - ANSI except the non-letter characters are all in weird places.
Also DEFINITELY buckling springs. You can see the spring sticking right out ffs! xD
Offline Oobly
« Reply #5 on: Fri, 20 February 2015, 02:36:31 »
The number on the plate is simply a part number.
That's definitely a buckling spring version and looks like you're right about Dutch layout. Clean it up, plug it in and type!
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Fri, 20 February 2015, 02:58:33 »
Looks like it might be part 1391511 if it's a blue logo version.
Offline gergo2007
« Reply #7 on: Fri, 20 February 2015, 15:02:36 »
The top looks like this. (Bonus root password included  :D )
Keys are cleaned, will clean the rest tomorrow.
« Last Edit: Fri, 20 February 2015, 15:06:52 by gergo2007 »
Offline chyros
  • a.k.a. Thomas
« Reply #8 on: Fri, 20 February 2015, 17:34:26 »
Not 1391511 then xD . Seems like whatever model number it is is not included in the Wikipedia list.
