Author Topic: Using a Wyse WY60 with a Windows 7 PC?  (Read 1989 times)
Offline Dead_Cheesecake
« on: Thu, 19 February 2015, 15:49:43 »
Hi, I'm new here.
A while ago I picked up a Wyse WY60. It's pretty cool. The only problem I have is, even after numerous hours of web searches and browsing, I can't find a way to use it with my Windows 7 computer. I believe the keyboard us a 4p4c connector, which can be plugged into the computer's rj45 ethernet port. Is it possible to set the keyboard/computer to work with each other, and if so how? Sorry if it's obvious or anything, I'm kind of a total n00b. If any further information is necessary, I will be happy to provide it.
Thanks,
Matt
Links that may be relevant?
http://vt100.net/wyse/wy-60-ug/wy-60-ug.pdf
http://www.kbdbabel.org/conn/kbd_connector_wyse.png
https://codingrush.files.wordpress.com/2014/05/usb.jpg
Re: Using a Wyse WY60 with a Windows 7 PC?
« Reply #1 on: Fri, 20 February 2015, 05:23:29 »
Soarer's WYSE Converter firmware should work with it.
You would have to get a Teensy 2.0 (or similar board with the right type of microcontroller on it), solder a 4P4C connector or cable to it and load the firmware onto it. If you don't install the converter inside the keyboard's case, then you might want to build a box for the controller also.
BTW. There are also people on the forum who lend their services if you don't want to/can't solder yourself.
« Reply #2 on: Fri, 20 February 2015, 14:22:07 »
Thanks for the help! I was wondering if this controller would work instead of the Teensy:
https://www.coolcomponents.co.uk/catalog/product/view/id/1385/s/a-star-32u4-micro/category/35/
Offline Tactile
« Reply #3 on: Fri, 20 February 2015, 16:51:35 »
That A-Star 32U4 Micro board you link to would probably might work. In Soarer's documentation he lists a Atmega32u4 sold by Adafruit as compatible & the one you link to appears similar.
There's a link to download the documentation in the first post of this thread...
https://geekhack.org/index.php?topic=17458.0
« Last Edit: Sat, 21 February 2015, 02:56:27 by Tactile »
REΛLFORCE
