Author Topic: Looking to build a 60% board for as cheap as possible  (Read 2666 times)
Offline Willyc277
« on: Thu, 19 February 2015, 22:52:53 »
Pretty satisfied with my current lineup (HHKB Pro 2, Poker II with clears, and Ducky DK9087 with blues), but I still want more. I feel like the only thing left to do at this point is build a new board myself. I'm a huge fan of the 60% layout so I think I'd like to slap one together! I'm really looking to go as cheap as possible in case I end up fecking it up! I've got a Poker II case I can throw it in so I'm covered there. Still haven't decided if I want a plate or not since I like the idea of being able to open up the switches for stickers/springs/lube pretty easily.
TL; DR: looking for a cheap 60% PCB and maybe a plate to go with it. Thanks!
Offline exitfire401
  • The Force is Re/\l
Re: Looking to build a 60% board for as cheap as possible
« Reply #1 on: Thu, 19 February 2015, 23:01:57 »
This is currently the cheapest way to go:
http://zealpc.net/products/gb
edit: Plate also allows for switch opening (as long as you don't have leds or have them in sip sockets)
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #2 on: Thu, 19 February 2015, 23:46:58 »
Well, if he want to wait for the gateron switches, he could buy like 70, get an acrylic plate cut, handwire, and throw a 20 set on, and that would be less if he finds a good deal on acrylic cutting. ponoko.com is really cheap as far as acrylic goes.
Offline Willyc277
« Reply #3 on: Thu, 19 February 2015, 23:52:45 »
Should have been more specific. I'm looking for a PCB and maybe a plate. I have a case and I'm in the Gateron GB. Thanks
Offline Willyc277
« Reply #4 on: Thu, 19 February 2015, 23:55:52 »
Excuse my ignorance, but what is a 20 set? I actually am waiting for the Gaterons, that GB make the decision to build a board much easier! Really looking for the cheapest PCB available at this point.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #5 on: Thu, 19 February 2015, 23:57:19 »
My bad, 20 dollar set.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #6 on: Thu, 19 February 2015, 23:59:13 »
If you really want cheap, go for the GH60, and order it from oshpark or something
Offline Oobly
« Reply #7 on: Fri, 20 February 2015, 01:22:05 »
Well, there's cheap and then there's inexpensive.
I recommend getting a GON NerD60 PCB ($55 from his site). You can also order stabilisers from him.
It's thick, high quality, fully programmable, comes with the main SMD components already soldered and looks awesome.
Then you'll have a Korean custom once you're done ;)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Willyc277
« Reply #8 on: Fri, 20 February 2015, 04:24:48 »
I'm looking to find one from the GH60 gb. $30 and pre-soldered.
Offline ideus
  • Björkö.
« Reply #9 on: Fri, 20 February 2015, 08:22:14 »
Chinese sites like taobao carry previous versions of the GH, and some are under $20 dollars, the process to get them into ConUs is not an easy task though.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #10 on: Fri, 20 February 2015, 09:57:22 »
qtan or tbfocus are your best bet.
Offline Defect
« Reply #11 on: Fri, 20 February 2015, 14:19:02 »
My first build was a 60%
Watermelon
Using cheaper parts, you could manage (prices in USD):
Pure PCB with stabilizers: 20
Case: $40-50 (or use the stock poker you have)
Switches: $30-40
Lube: $5
Cheap ABS Caps: $5-15
I built another 60 using a Face-W PCB from Zeal.  Easy to remap and program.
« Last Edit: Fri, 20 February 2015, 14:21:24 by Defect »
