Author Topic: How does this typewriter keyboard work?  (Read 2877 times)
Offline nakedninja
« on: Fri, 20 February 2015, 10:53:34 »
I've been disassembling an old electronic typewriter in my spare time and as I took apart the keyboard (to see if I could repurpose it as a computer keyboard, don't think I can) the setup confused me.
It has rubber domes that press down onto two plastic (maybe silicon) sheets. I don't understand.
I have some pictures on my potato - perhaps they will tell the story better.
If you can, explain like I'm brand new, thanks.
Offline Dihedral
  • Mostly Harmless
Re: How does this typewriter keyboard work?
« Reply #1 on: Fri, 20 February 2015, 11:04:08 »
This is a very common type of design for membrane boards. I believe it works by pressing the two sheets together - cheaper than metal contacts.
« Reply #2 on: Fri, 20 February 2015, 11:08:05 »
From the ones I've seen similar to that, there's three sheets, a top layer with traces, a mix layer with cutouts, and a bottom layer with traces.  When you depress the switch, the top sheet moves and makes contact with the bottom sheet, completing the circuit.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Fri, 20 February 2015, 11:27:25 »
It's a standard rubber dome over membrane keyboard, practically all modern keyboards have this. The plastic sheets and rubber mats are a fraction of the cost to manufacture compared to a PCB with individual, quality switches for each key. The downside of course is that it's about as ****ty as diarrhoea.
Offline 0100010
  • Not Sure
« Reply #4 on: Fri, 20 February 2015, 13:22:51 »
You could convert that to USB.  Question is, with it being rubber dome - would you still want to?
Offline FrostyToast
  • Litshoard
« Reply #5 on: Fri, 20 February 2015, 13:25:32 »
Could be the next Topre.
Kek.
Quote from: elton5354
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #6 on: Fri, 20 February 2015, 14:46:04 »
Interesting, looks like NMB sliders …
Bore Awards
Offline chyros
  • a.k.a. Thomas
« Reply #7 on: Fri, 20 February 2015, 17:33:07 »
Almost certainly, yes:
Offline nakedninja
« Reply #8 on: Sat, 21 February 2015, 08:43:43 »
Hey, thanks for all the replies. I probably can't be bothered to convert it to be honest, but am fascinated to learn how it works.
Now to find a use for it.
  • RIP
    • Boring twaddle
« Reply #9 on: Sat, 21 February 2015, 08:57:28 »
Just to be clear, do you understand it now, or are you still seeing further explanation?
You might find the exploded diagram here useful:
http://deskthority.net/wiki/Rubber_dome_over_membrane
Bore Awards
Offline nakedninja
« Reply #10 on: Sun, 22 February 2015, 04:48:12 »
Thanks, I think I have it now.
