Author Topic: Does this keyboard have Vintage MX Blacks?  (Read 1647 times)
Offline Rotaku
  • Too Based
« on: Fri, 20 February 2015, 14:20:12 »
Hey guys I recent picked up the keyboard in this post: http://www.ebay.com/itm/Wyse-Link-General-Terminal-Keyboard-Enhanced-PC-PCE-50-120-000-102-EPC-RJ11-US-/331485175996? and I was wondering if it had vintage blacks?
« Last Edit: Fri, 20 February 2015, 15:17:30 by Rotaku »
Not toooo active on GH anymore, if you need me, shoot me a PM on Reddit! /u/IchibanXD
Re: Does this keyboard have Vintage MX Blacks?
« Reply #1 on: Fri, 20 February 2015, 14:58:41 »
Vintage is hype.  Aged broken in Blacks is what matters.
And Wyse boards have a hodgepodge of three or four different Blacks, "vintage," old, new, and other old ones.  You never know what you're gonna get.
« Reply #2 on: Fri, 20 February 2015, 15:02:38 »
Yes, and most likely they will be mixed within the same keyboard. You will have to visually inspect each switch to tell if it's a vintage switch or not.
Offline FrostyToast
  • Litshoard
« Reply #3 on: Fri, 20 February 2015, 15:04:11 »
I would say that it is more important to look at the date of the board.
I have a G80-2100 from 1994. It's not that old, but it's used as hell and just as smooth.
There is also Gatorade hype.... In case you aren't aware, Gatorade is a mockery of the company Gateron which is said to make the smoothest, and tightest stock linear switches.
Pretty much the only Cherry clone to consider.
EDIT :triangle:
« Last Edit: Fri, 20 February 2015, 15:25:57 by FrostyToast »
Quote from: elton5354
Offline Rotaku
  • Too Based
« Reply #4 on: Fri, 20 February 2015, 15:21:07 »
Thanks guys for the help :)
