Author Topic: LED Color Changer with PBT caps  (Read 1861 times)
Offline m1hka
« on: Fri, 20 February 2015, 15:54:59 »
Hello,
There's massdrop with LED Covers has started. I'd like to know if standard Poker II PBT keycaps stuck on LED Covers on not.
I've googled for 2 hours and didn't find the answer. There were some reports that thick caps stuck but they aren't really trustworthy.
I'd like to know for sure.
Offline Firebolt1914
  • POM Overlord
Re: LED Color Changer with PBT caps
« Reply #1 on: Fri, 20 February 2015, 16:08:57 »
I'm not sure if I understand what you're trying to say; do you mean the keycap getting stuck on the led cover?
Offline m1hka
« Reply #2 on: Fri, 20 February 2015, 16:18:36 »
Yeah. I'm asking if I can use LED Covers with default PBT keycaps on Poker II.
« Last Edit: Fri, 20 February 2015, 16:20:08 by m1hka »
