Author Topic: New Poker II--not enjoying my feels  (Read 3015 times)
Offline mercuria
« on: Sat, 21 February 2015, 17:58:50 »
I got a clear switch Poker II, and it has an inconsistent feel between rows. The number row feels good, but the rest of the rows lack that solid feel. It's really disapointing compared to my husband's red switch Leopold 750. Is there anything I can do to address the rest of the rows, or is it just inherent to the Poker II? Will a better case help?
Offline Lastpilot
  • Power stance
Re: New Poker II--not enjoying my feels
« Reply #1 on: Sat, 21 February 2015, 18:11:12 »
Number row usually does feel a little better because the keycaps are larger and have less resonance. The Leopold 750 has a mat beneath the PCB that helps with sound absorption and harsh bottom-outs, so that's probably why it feels better.
So you can try unscrewing your Poker and putting some shelf liner between the case and circuit board. That might help.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #2 on: Sat, 21 February 2015, 18:24:44 »
It's partly the case. The default plastic case is rather light, so you might try putting a rubber mat beneath the keyboard to see if that produces a better feel.
Offline derb2k2
  • Something of a Topre ****..
« Reply #3 on: Sat, 21 February 2015, 18:41:56 »
sorry to hear that. I don't think this is a prevalent problem with Poker IIs. I remember getting mine with blue switches and I tested for consistency right away. I was very satisfied with the results.
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
Offline mercuria
« Reply #4 on: Sat, 21 February 2015, 18:56:05 »
I tried the shelf liner under the PCB already, and it made the feel slightly worse, more mushy. The shelf liner under the whole case made it feel better overall, but didn't help with the row differences.
I'm not sure how to explain it. If I hit the number row hard, there's a thock when it bottoms out, where it actually stops. The other rows feel more like I've hit soft dirt, and it's more of a thud. When just typing, the number row feels more "clean."
« Last Edit: Sat, 21 February 2015, 18:59:05 by mercuria »
Offline mashby
    • Mashby
« Reply #5 on: Tue, 24 February 2015, 13:44:07 »
That's odd that you're feeling a difference between the rows. Glad to hear that the shelf liner under the keyboard helped, but sorry to hear it wasn't a total solution. Do you have any other key caps you could try?
Offline sdothum
« Reply #6 on: Tue, 24 February 2015, 14:19:26 »
Did you "seat" the keys? When I got my Poker 2, I noticed that most of the keys needed to be seated. Pressing firmly on each keycap, I could feel it seat downwards (I'm assuming it's the keycaps not being completely seated on the Cherry stems -- the plate and switches look pretty solid).
Not sure if loose keycaps would account for the variance in feel you are experiencing.
Planck - Cherry Black Silent 62g - Signature SA (Primary driver)
Planck - Gateron Brown - Gateron Cherry PBT
Planck - Zealios Tactile 62g - Gateron Cherry PBT
Planck - Matias Quiet Linear - 3D Printed Steno Keycaps
Out of circulation (Ortho all the way!): Poker 2 (MX Red), Filco Majestouch (MX Blue)
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #7 on: Tue, 24 February 2015, 16:48:14 »
How odd — my Poker II's feel is completely consistent and rock solid. The stabilised keys feel a bit different, as they have Cherry stabilisers, but that's to be expected.
This Poker II was new? Or second-hand?
Bore Awards
Offline mercuria
« Reply #8 on: Mon, 02 March 2015, 14:55:17 »
Well! I think this has all been entirely my fault. (Sorry for the delay; been without real internet for a week)
I re-tried the shelf liner thing, but without the last layer of shelf liner (the full sheet) and that helped a bit. While I was doing this, I noticed that the problem exists outside of the case. I swapped keycaps between rows, and the problem follows the keycaps.
I think it might be the Leopold keycaps I have on it (I swapped them pretty much as soon as I got the thing because I really dislike the way the stock keycaps look), which makes me pretty pouty. I don't have the stock keycaps here, so I'll have to do some traveling to see if the stock keycaps have the same problem. I'm guessing they don't :mad:
Anybody know where I can get thick OEM PBT side prints without the vortex dimples?
« Last Edit: Mon, 02 March 2015, 14:57:12 by mercuria »
Offline mercuria
« Reply #9 on: Wed, 04 March 2015, 09:07:22 »
Quick update: Putting the ugly stock keycaps back on fixed it. I'd assumed it wasn't the keycaps because the same keycaps on the red FC750 don't have this problem.
Offline munch
« Reply #10 on: Wed, 04 March 2015, 12:30:14 »
could it be that the mounting part on the stem is different between the boards? so it doesn't quite go all the way "in"?
Offline mercuria
« Reply #11 on: Thu, 12 March 2015, 13:08:36 »
I think it's more about what Lastpilot mentioned in his first reply (the larger keycaps). I think shorter, smaller Leopold just didn't have the presence that the OEM keycaps did. I'm guessing it wasn't an issue on the reds because of the weaker springs.
