Author Topic: Hand Sanitizer and Legends  (Read 2265 times)
Offline brimborion
  • Likes Matias Switches
« on: Sun, 22 February 2015, 00:50:35 »
Sometimes I keep some hand sanitizer at my desk and use it while I am seated at my keyboard. It occurred to me that maybe this was not a good idea because if it doesn't dry completely before I type again, it might remove my keycap legends? I don't know of any issues with it but I'm not sure if down the road it might haste the removal of legends or discolor the key caps. Maybe sometime I'll find some spare caps and just squirt the stuff on there, I guess it's mostly alcohol and probably evaporates quickly enough to not be a real problem.
Does anyone know more about this?
Buckling Spring: 42H1292,  1391401, Unicomp Linux 101, Customizer 104 | Cherry Blue: Rosewill RK-9000, Das Keyboard S Pro | Cherry Black: Wyse/Link 840358-30| Rubber Dome: various Key Tronic, HHKB Lite, HHKB Lite 2, KB-8923, 71G4644 | Topre: Type Heaven | ALPS: Matias Mini Tactile Pro, 2xKBP V60
Re: Hand Sanitizer and Legends
« Reply #1 on: Sun, 22 February 2015, 03:20:14 »
Soap and water are best for cleaning your hands.
« Reply #2 on: Sun, 22 February 2015, 10:00:48 »
Yes, it is.
Double shot caps are immune to anything, including sandpaper.
Dye subs are almost as good, as are laser-etched, in this scenario.
Pad-printing, however, might be quite vulnerable to chemicals.
- Franklin Roosevelt 1933
Offline hking0036
« Reply #3 on: Sun, 22 February 2015, 14:20:56 »
Yes, it is.
Also UV-Coating (although not as common) will pretty much melt on contact with alcohol.
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
