Author Topic: Sun Aged Plastic  (Read 3854 times)
Offline lecorsair
Sun Aged Plastic
« on: Tue, 25 August 2009, 02:24:46 »
Anyone know, or can recommend the best method by which to refurbish an originally white keyboard that has been yellowed through exposure to UV light. I've read a quite a few posts which state categorically NOT to bleach plastic. But I've also read a few accounts of people successfully removing the yellowness by using bleach. Anyone here have first hand experience?
If that bleaching doesn't work, I'm pondering RIT-dying the keyboard. Any recommendation for color selection - if the keyboard is white, with black lettering? Specifically, this would be for an older Apple keyboard. Thanks!
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Sun Aged Plastic
« Reply #1 on: Tue, 25 August 2009, 02:51:34 »
There are about half a dozen links on the topic of yellowing in the Keyboard Links wiki which I suggest you take a look at. Not bleaching refers to chlorine bleach in particular.
Offline itlnstln
Sun Aged Plastic
« Reply #2 on: Tue, 25 August 2009, 08:15:16 »
Toothpaste. See the mods section for more info. Basically, brush the case/keys with toothpaste; it's pretty straightforward. You will see magnificent results. Be sure to use whitening toothpaste but nothing special, though, you can do this with regular whitening stuff.
« Last Edit: Tue, 25 August 2009, 10:21:21 by itlnstln »
Offline lowpoly
Sun Aged Plastic
« Reply #3 on: Tue, 25 August 2009, 09:14:55 »
No progress with my retrobright project so far. Still have no tanks/bowls/trays. What's the right word here?
Offline o2dazone
Sun Aged Plastic
« Reply #4 on: Tue, 25 August 2009, 09:27:51 »
Quote from: itlnstln;111729
You will magnificent results.
I believe you just the entire internet.
Offline itlnstln
Sun Aged Plastic
« Reply #5 on: Tue, 25 August 2009, 10:21:43 »
Quote from: o2dazone;111745
Nice.  Edited.
Offline clickclack
  • Board Chow EXTRAORDINAIRE
tan lines FTW!
« Reply #6 on: Tue, 25 August 2009, 14:50:07 »
WHATEVER poeple!
Tan lines are sexy!!!
Bwaahahahahahaaaaaaa!!! =P
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline timw4mail
    • https://timshomepage.net
Sun Aged Plastic
« Reply #7 on: Tue, 25 August 2009, 15:03:41 »
Quote from: clickclack;111812
WHATEVER poeple!
Lol, those keys do have tan lines...
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline lecorsair
Sun Aged Plastic
« Reply #8 on: Tue, 25 August 2009, 15:06:13 »
WHATEVER poeple!
Ohhh...hawt!
Offline huha
Sun Aged Plastic
« Reply #9 on: Tue, 25 August 2009, 21:02:23 »
Quote from: lowpoly;111740
I think it's guts.
For the record, you better not store the chemicals needed next to PCB cleaners. Unless, of course, you'd like to play Who Wants To Be A Terrorist.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline lowpoly
Sun Aged Plastic
« Reply #10 on: Wed, 26 August 2009, 03:31:17 »
No, it's not guts. :-)
I meant these:
This stuff is not funny. I have a chemist helping me.
Offline ed_
Sun Aged Plastic
« Reply #11 on: Thu, 27 August 2009, 00:36:49 »
I used a $2 disposable aluminum baking pan for (unsuccessfully) dying a Model M mini; it had a couple of inches of room on each side.  Don't know if there are any that will hold a full-sized keyboard, though.
Could try lining a cardboard box with some aluminum foil, using some resilient tape to seal the seams.
Offline watduzhkstand4
Sun Aged Plastic
« Reply #12 on: Thu, 27 August 2009, 00:40:57 »
those keys look yummy.
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
