Author Topic: Model M button problem  (Read 2031 times)
Offline Rapsodia
« on: Sun, 22 February 2015, 17:28:13 »
Hi there,
I've got a Model M keyboard 139101 and I have a slight problem with my Numpad's "0" Insert Key. Whenever I press it I don't hear the click after one point, as with the other buttons. Have a look at the spring http://goo.gl/QWC2wi
Do you happen to have any idea about the problem?
Thanks,
George
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Model M button problem
« Reply #1 on: Sun, 22 February 2015, 17:39:57 »
Have you opened the keyboard up? Sounds a bit like a few of the plastic rivets might have snapped off around that area.
Offline brimborion
  • Likes Matias Switches
« Reply #2 on: Sun, 22 February 2015, 17:43:20 »
Also, try tilting the keyboard forward while reseating the cap. That can get the spring back in the sweet spot where it clicks again. Your spring looks a little bent but I don't think that's the issue.
Buckling Spring: 42H1292,  1391401, Unicomp Linux 101, Customizer 104 | Cherry Blue: Rosewill RK-9000, Das Keyboard S Pro | Cherry Black: Wyse/Link 840358-30| Rubber Dome: various Key Tronic, HHKB Lite, HHKB Lite 2, KB-8923, 71G4644 | Topre: Type Heaven | ALPS: Matias Mini Tactile Pro, 2xKBP V60
Offline Rapsodia
« Reply #3 on: Sun, 22 February 2015, 17:44:19 »
OK I'll do it tomorrow and I'll report back. Thank you!
Offline 1391406
« Reply #4 on: Sun, 22 February 2015, 19:06:01 »
Based on the pic, the top of the spring looks like it could be damaged.
« Reply #5 on: Sun, 22 February 2015, 19:11:28 »
Absolutely. That spring is a goner. It will have to be replaced.
- D Trump 2026-10-24
Offline keyhopper
  • Fun is Key.
« Reply #6 on: Sun, 22 February 2015, 21:04:42 »
Unicomp sells the springs:
       "Pivot Plate & Spring Assembly"
       http://www.pckeyboard.com/page/Misc/PVPLASM
Cheers!
.KeyHopper.
RealForce 87UB 55gr    |    IBM Model M (1995)    |    Razer B.W.T.E. Stealth (w Razer oranges)
Offline arakula
« Reply #7 on: Mon, 23 February 2015, 00:48:48 »
Replacing it would surely be the best.
As a temporary solution, it might be possible to bend the spring back into shape. Fiddly work, and I've never been 100% successful at it, but at least I've been getting a click again, just not the same click of the other keys around.
Offline Rapsodia
« Reply #8 on: Mon, 23 February 2015, 03:44:35 »
What a fantastic community! Thank you all for the answers!
Now, have a look at the keyboard's backplate: http://goo.gl/boCIIw
Seems that many rivets are already broken, but the insert key rivet (bottom row, 2nd from the left) is OK.
I'll try fixing that spring, even I have tried unsuccessfully in the past. Correct me if I'm wrong, but replacing the spring requires cut down of all rivets and then appliying the screw mod, which seems rather tricky (especially the drilling process).
God, I love my Model M!
Waiting for your feedback.
« Reply #9 on: Mon, 23 February 2015, 07:25:14 »
There are techniques for replacing springs in situ.
I have never done it, but there is the "Chopstick of Death" as well as a much more elegant procedure involving a modified pop rivet body.
They are both buried in here somewhere.
https://geekhack.org/index.php?topic=63278.msg1482918#msg1482918
Offline Rapsodia
« Reply #10 on: Mon, 23 February 2015, 15:01:04 »
thanks, I'll check these out.
