Author Topic: Looking for Inexpensive, Blank Keycaps. (And also general information.)  (Read 5413 times)
Offline Wulfre
I am open for colors, but I am looking mostly for Black/Grey/Purple/Brown, or somewhere in that area.
I am fairly new to the keyboard community, so I have no idea what the difference between plastics, what size keys I need, or even where to start looking for supplies.
Because I am so new I don't really know if it is worth paying more than $25 for caps, even though I really want to customize my keys.
I also hope I posted this in the right place.
Re: Looking for Inexpensive, Blank Keycaps. (And also general information.)
« Reply #1 on: Sun, 22 February 2015, 18:45:57 »
Welcome to Geekhack!
As good a place as any to ask :)
Purple (well, lavender) for $20, you won't get much cheaper than that:
http://www.elitekeyboards.com/products.php?sub=access,cherrymxkeys&pid=dmx_us104_lav_np
Or, how cheap were you thinking?
brown btw you won't find many sets at all.  Grey is surprisingly rare, Ducky had some sets, but they might not have been blank and were 3 to 4 times more expensive than the set linked above.
Black sets are all over the place.
PMK has some DSA blank sets:
http://keyshop.pimpmykeyboard.com/products/blank-key-packs
http://keyshop.pimpmykeyboard.com/products/full-keysets/dsa-blank-sets-1
Offline Wulfre
« Reply #2 on: Sun, 22 February 2015, 18:56:37 »
I found these, though I am not sure about the plastic, and white is also much lighter than I was looking for, on the other hand I could possibly dye them.
http://www.geekkeys.com/blank-pbt-104-keyset/
« Reply #3 on: Sun, 22 February 2015, 19:06:06 »
PBT is good - it won't shine (not for a very long time).
Also that set will suit a standard ANSI layout - which keyboard have you got?
Offline Wulfre
« Reply #4 on: Sun, 22 February 2015, 19:11:17 »
I have a CM Storm QuickFire Rapid (TKL).
Thanks for the help, too.  :)
« Reply #5 on: Sun, 22 February 2015, 19:39:17 »
QFR - excellent keyboard!  And fortunately a completely standard layout, so pretty much any set you choose should fit.
Offline Wulfre
« Reply #6 on: Sun, 22 February 2015, 19:41:20 »
I looked around Epic Keyboard and I am liking the blue with a lavender cluster.
I'll just leave this crude photo edit here to see if anyone has an opinion.
« Last Edit: Sun, 22 February 2015, 19:56:40 by Wulfre »
« Reply #7 on: Sun, 22 February 2015, 20:43:34 »
Elite Keyboards?
I have a green printed set.  It is ok, about what you'd expect for the price.
The printed ones are pad printed, so the legends are likely to wear off after a while.  The blank ones obviously have no legends.
In general people weren't unimpressed by the keycaps ;)
Offline Wulfre
« Reply #8 on: Sun, 22 February 2015, 21:04:07 »
Yes, I meant Elite Keyboard. I have no idea where I got the world epic from.
I might buy them next week, I'll put some pictures if I do, but you can probably expect exactly what you saw in the fake picture above.
« Last Edit: Sun, 22 February 2015, 21:06:33 by Wulfre »
Offline KHAANNN
« Reply #9 on: Sun, 22 February 2015, 21:27:57 »
Thanks for the link, I remember checking each keyseller, yet I somehow missed this: http://www.geekkeys.com/blue-grey-printed-thick-pbt-108-keyset/ bought it without much thinking
I suggest you do the same, decent PBT sets are extremely hard to find, don't mess with ABS's much if you can avoid it
(just saw the blank requirement, I strongly suggest DSA/pbt's in that case, although I haven't tried it myself, I was aspiring to get a set myself)
Offline hking0036
« Reply #10 on: Sun, 22 February 2015, 21:35:21 »
ABS can be great, just that some are better than others. It really depends on who's making, some can be thin and others not. CHEAP anything is obviously gonna be thinner and generally more fragile.
That said, for reasonably cheap blanks SP's blank DSA's seem pretty popular so might be a safe option.
« Last Edit: Sun, 22 February 2015, 21:37:48 by hking0036 »
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
Offline Wulfre
« Reply #11 on: Sun, 22 February 2015, 21:58:59 »
I assume you are talking about this? http://keyshop.pimpmykeyboard.com/products/full-keysets/dsa-blank-sets-1
I had found this set, but I am not sure if the quality will be compromised much. They are made of PBT so I expect them to be at least a bit thicker, even if they are thinned down for cost. http://www.geekkeys.com/blank-pbt-104-keyset/
Offline hking0036
« Reply #12 on: Sun, 22 February 2015, 22:34:38 »
Feng's stuff is typically alright, and I think that SA and those thicknesses are about the same (citation needed). Either way you're probably doing better than stock caps with either of those options.
Offline Oobly
« Reply #13 on: Mon, 23 February 2015, 05:59:02 »
http://www.newegg.com/Product/Product.aspx?Item=9SIA2C517C9755
They're most likely the same profile and thickness as the ones from Feng (Keycool brand medium thickness). The white ones are PBT, the black ones are POM.
If you can find them on Banggood, they'll be a little cheaper, but they take a long time to ship.
I love my POM caps :) The feel really nice to type on. Slightly "teflon-like" surface texture, denser than PBT, so they're a little heavier.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline drewba
« Reply #14 on: Mon, 23 February 2015, 16:46:24 »
I took a picture awhile back for someone on the GH irc channel regarding key thicknesses; this may or may not help. For what it's worth, I can recommend both the blank PBT keyset on geekkeys as well as the blank ABS keyset on elitekeyboards. Both should be ~$25 after shipping. If you decide on elitekeyboards, their keysets ship in a carrying case which is great for storage.
FYI I dyed the PBT geekkeys in case you're wondering why they aren't white  :D
Offline Wulfre
« Reply #15 on: Mon, 23 February 2015, 16:51:19 »
This is a bit off-topic for the thread, but I didn't exactly want to make a whole new thread.
People have been complaining that I bottom out too much, so I was planning on just picking up some generic o-rings from the hardware store. Would these suffice? I am not entirely sure on the measurements I would need to look for.
http://www.amazon.com/008-Buna-N-O-Ring-Durometer-Black/dp/B000FMWLR8/ref=zg_bs_16413421_1
Offline Oobly
« Reply #16 on: Tue, 24 February 2015, 04:05:21 »
70A is pretty hard, harder than the ones sold for use on keyboards.
I'd get some "proper" ones, they're not expensive.
Offline ianbullock
« Reply #17 on: Tue, 24 February 2015, 20:23:23 »
I tried those O-rings on a MX brown QF TK - I personally wasn't a huge fan. They are quite thick, so the travel is reduced quite a bit. That could be a good thing for some but I had trouble getting used to it, just felt mushy and less satisfying (but maybe all O-rings would do that). Sound was reduced a bit but not a ton. Maybe I just don't want to give up the clackiness.
On the other hand, it's only $2 and might give you a feeling of whether you should be getting a more expensive o-ring set or not.
Offline Oobly
« Reply #18 on: Wed, 25 February 2015, 06:52:38 »
Wow! Seems the US keyboard companies have massive markup on their orings. Seriously, $18 from WASD? ridiculous. You can find cheap ones on Amazon or eBay, though. Look for 40A or 50A orings in 3/16" ID, 5/16" OD (1/16" thickness).
Keyboardco sells them for reasonable prices in UK: http://www.keyboardco.com/product/o-ring-switch-dampeners-for-filco-keyboards.asp
Offline Wulfre
« Reply #19 on: Wed, 25 February 2015, 15:03:18 »
That's why I didn't want to pay full price for them.
Offline Asininity
« Reply #20 on: Thu, 26 February 2015, 23:34:55 »
Elite Keyboards?
I was looking at elitekeyboards red blank set. Does the set come with two keys that have raised bumps for the J and F key?
Offline vmod
« Reply #21 on: Fri, 27 February 2015, 01:37:30 »
Cheap most likely would be on banggood and ebay. And PBT quality cannot be that bad that you can't use them at all.
« Reply #22 on: Fri, 27 February 2015, 04:11:40 »
Elite Keyboards?
These ones? http://www.elitekeyboards.com/products.php?sub=access,cherrymxkeys&pid=dmx_us104_red_np
If so, then yes, F and J have nubs (see the 5th pictures in the first post):
https://geekhack.org/index.php?topic=47311.0
Offline Asininity
« Reply #23 on: Fri, 27 February 2015, 10:32:30 »
Elite Keyboards?
Thank you! I think I'll be grabbing a set of these.
Offline MajorMajor
  • Mechanical Keyboard Enthusiast
    • Coding Supply
« Reply #24 on: Fri, 27 February 2015, 11:46:42 »
I picked up a blank white set from banggood.com, took awhile to arrive but they're good quality.
TKL / Clears / Dvorak / Flipped Space for Life / Best Programming Keyboards
