Author Topic: JP layout on windows7 US  (Read 1880 times)
Offline gcb
« on: Tue, 24 February 2015, 13:55:17 »
got a topre with JP layout. but windows just see it as a US keyboard.
i tried to set it to use the  "106key JP" driver. but then it became a paper weight. nothing works.
any ideas what i should do?
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
Re: JP layout on windows7 US
« Reply #1 on: Tue, 24 February 2015, 13:58:58 »
You probably need the Japanese language pack?
http://windows.microsoft.com/en-us/windows7/products/features/language-packs
I think you may need Windows 7 Ultimate or Enterprise?
« Reply #2 on: Tue, 24 February 2015, 14:15:49 »
i don't even know if you need this but download it and give it a try
Offline Valen
« Reply #3 on: Tue, 24 February 2015, 21:03:17 »
Windows may not use the correct keyboard layout when you connect a USB keyboard to the computer so this is what I did.
http://support.microsoft.com/kb/927824
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Tue, 24 February 2015, 21:41:41 »
I had a Cherry Japanese layout keyboard. Just need to go into the control panel language settings, add keyboard, choose Japanese. You'll then be able to select it with the ALT+SHIFT. It's all about the keymap, no special driver or other nonsense should be necessary. No different than any other language keyboard. The legends on the keycap don't tell the computer what it is, you need to assign the computer the corresponding keymap.
« Last Edit: Tue, 24 February 2015, 21:43:31 by IvanIvanovich »
