Author Topic: Hhkb help  (Read 1691 times)
Offline steve.v
Hhkb help
« on: Tue, 24 February 2015, 17:38:30 »
To remove the spacebar, can I just pull it up?
Offline steve.v
Hhkb help
« Reply #1 on: Tue, 24 February 2015, 17:40:32 »
I got the two sides to pop but it seems something is holding it in the center. I got a type s if that matters.
« Last Edit: Tue, 24 February 2015, 17:48:16 by steve.v »
Offline Bomble
Re: Hhkb help
« Reply #2 on: Tue, 24 February 2015, 17:50:18 »
The center is where the keycap attaches to the Topre slider, if you carefully pull up with equal pressure along the space bar then it should pop off relatively easily. I also found it difficult to remove mine the first time I tried but if you are careful then you should be fine.
Offline steve.v
Re: Hhkb help
« Reply #3 on: Tue, 24 February 2015, 17:54:23 »
Thank you. You are right. It was hard, it flew up and out, saw a spring. Thx.
Offline Ludovician
Re: Hhkb help
« Reply #4 on: Tue, 24 February 2015, 18:11:40 »
Yeah, I've heard stories of that spring flying off and never being seen again.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline Bomble
Re: Hhkb help
« Reply #5 on: Tue, 24 February 2015, 18:23:51 »
No worries mate.
