Author Topic: G80-8200HPBUS Keycap Compatibility ?  (Read 3099 times)
Offline metafour
« on: Wed, 25 February 2015, 01:35:50 »
Are the mods and caps lock on a G80-8200HPBUS compatible with modern MX boards? The caps lock looks full-touch but is it center stemmed? The mods are 1.25x but are they center stemmed? It has a big ass enter but that might be easier to find replacements for.
http://m.ebay.com/itm/230993460290?nav=SEARCH
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: G80-8200HPBUS Keycap Compatibility ?
« Reply #1 on: Wed, 25 February 2015, 01:37:02 »
They're all center stemmed however the menu and windows keys are pad printed. The rest of the mods should be doubleshot though.
Offline metafour
« Reply #2 on: Wed, 25 February 2015, 01:42:08 »
Thanks. I do vaguely remember that some of the 1.25x mods are pad printed from the set I had previously.
Offline bueller
  • MX baller
« Reply #3 on: Wed, 25 February 2015, 01:51:16 »
Yeah, such a shame :(
If you wind up getting a set and want to part with the numpad alphas or want to swap for normal ones with sub-legends let me know - I love the cut-down look of the ones on the 8200 boards.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Wed, 25 February 2015, 12:41:20 »
Yes, they are fully compatible with other board like Filco, Ducky, Kul, CM, Leopold, etc 87/104 key except the spacebar and some model with US layout still come with an ISO enter key.
Offline NorrisB
« Reply #5 on: Sun, 01 March 2015, 10:49:29 »
Look at that right enter key, I see atleast 2 keys on the right side that are messed up can those F keys be salvageable with those clear caps?
Offline NorrisB
« Reply #6 on: Sun, 01 March 2015, 11:03:32 »
