Author Topic: Tweaking a nav cluster on AT Model F a bit.  (Read 3465 times)
Offline mougrim
« on: Wed, 25 February 2015, 05:19:57 »
I decided to change nav cluster a bit, cuz I want all important buttons to be really close. That's what I got after step 1.
Now I thinking...
As I had remapped my Caps Lock to Control, why not use 8 on numpad as Caps Lock (only one of "Lock" keys I really use).
As I don't have any use for Num Lock and Scroll Lock now (obviously) I consider remapping Num Lock to Pause/break, Scroll Lock to Print Screen/SysRq), moving asterisk and minus one unit up, addin one unit + buttong and replacing big + button with Enter. But I don't know if Model M numpad enter can be installed on F...
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline E TwentyNine
    • Some of My Keyboards
Re: Tweaking a nav cluster on AT Model F a bit.
« Reply #1 on: Wed, 25 February 2015, 07:31:02 »
You might consider going a little further:
Once you open up the board and rearrange the barrels the possibilities are many.
Offline mougrim
« Reply #2 on: Wed, 25 February 2015, 07:44:05 »
Too radical for me. And I don't like all that unfulled holes ;)
Offline jacobolus
« Reply #3 on: Wed, 25 February 2015, 07:54:58 »
It seems to me like with a full numpad to work with, you could get more comfortable and faster arrows with an arrangement along the lines of:
where left = index finger, up = middle finger, right = ring finger, down = thumb.
« Reply #4 on: Wed, 25 February 2015, 08:02:47 »
I've been meaning to figure out a cover for the holes, haven't gotten to it.
But it's not for everyone.  Someone over at DT (and here) did do a rearrangement of the cluster keeping all the keys but turning most (all?) of them to single unit.  Forget what the thread was.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #5 on: Wed, 25 February 2015, 08:21:55 »
I did it with mine.  All the pads are there under the barrels.  Just need to pull the plate, add springs with flippies, tweak the layout on the firmware side and put caps on.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #6 on: Wed, 25 February 2015, 08:37:41 »
Go even further
« Reply #7 on: Wed, 25 February 2015, 08:53:41 »
Muirium at Deskthority did this and it really got me going.
When I get around to modding my AT, it will be more like this:
- D Trump 2026-10-24
Offline JPG
  • Model F is my new passion!
« Reply #8 on: Wed, 25 February 2015, 09:02:53 »
While I understand the fun of modding the keyboard and replacing this bigass enter and/or the small backspace, I just don't get why people want to change the NAV cluster on the AT F since it already has a very nice nav cluster to it.
Anyone can enlighten me? Maybe it's because I don't use it as a numpad at all and let it configured as a pure NAV cluster all the time, but for me it works very well. More so since I also have a second layer NAV cluster around ijkl, so I only use the NAV cluster on the numpad when I need to use the mouse at the same or when my hands are not well placed on the keyboad for whatever reason.
Show me the light!
« Reply #9 on: Wed, 25 February 2015, 09:07:16 »
I use the numpad constantly, and, in fact, on my F-122s I have removed the "numlock" key entirely - it does not even exist on the keyboard.
Dedicated numpad, arrows, and page up/down are essential to me. Back in the 1980s, I never learned to use the "navigation cluster" built into the numpad, and so, for me, it does not exist.
« Reply #10 on: Wed, 25 February 2015, 09:14:02 »
Same here with the dedicated cursor keys and nav six-pack.
While the AT has superior construction and internals, it lacks in the layout department.  Not as bad as the XT, but inferior to the SSK.
The inverted-T cursor layout has stuck around for a reason.
Offline mougrim
« Reply #11 on: Wed, 25 February 2015, 10:22:01 »
Hmm... Not bad. But to do all this and not replace stepped keys?
« Reply #12 on: Wed, 25 February 2015, 10:31:44 »
Ha Ha Ha
Some of us LOVE stepped keys!
Offline mougrim
« Reply #13 on: Wed, 25 February 2015, 11:03:20 »
Ha Ha Ha
I know SOMEONE had to love them, but I thought all people who actually do worked in IBM team, which created XT keyboard. And probably faced firing squad right after that :)
Offline mougrim
« Reply #14 on: Fri, 27 February 2015, 06:38:24 »
OK, I'm almost created an ideal nav cluster for me - I remapped Numpad 8 to Backspace and + to Enter - now i can edit text and navigate in Total Commander and FAR with one hand :)
I have M-style Numpad Ener key and, of course, original 1-unit Backspace, so all I need now is one-unit Caps Lock. Whish I need to order from Unicomp. Damn :)
