Author Topic: Can you buy and apply coatings to key caps?  (Read 2061 times)
Offline brimborion
  • Likes Matias Switches
« on: Wed, 25 February 2015, 15:36:28 »
I noticed I like whatever coating is on my Type Heaven's ABS keys, and also whatever coating is on my KBP v60 MTS. If I found a texture I liked, would it be possible to spray it on any other ABS caps that are starting to shine or that I just find too smooth? I don't really care if they are opaque and cover the legends, though if they are clear, even better. I hear stuff like "UV coated" and wonder if I can just buy a can of it and squirt it all over my Rosewill or something.
Buckling Spring: 42H1292,  1391401, Unicomp Linux 101, Customizer 104 | Cherry Blue: Rosewill RK-9000, Das Keyboard S Pro | Cherry Black: Wyse/Link 840358-30| Rubber Dome: various Key Tronic, HHKB Lite, HHKB Lite 2, KB-8923, 71G4644 | Topre: Type Heaven | ALPS: Matias Mini Tactile Pro, 2xKBP V60
Re: Can you buy and apply coatings to key caps?
« Reply #1 on: Wed, 25 February 2015, 18:59:05 »
not that i know of
and it'd probably peel off and look gross anyway
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Sun, 15 March 2015, 12:01:40 »
The process involves an UV tunnel.
Plastidip is something that has been used on keycaps before.
« Reply #3 on: Mon, 16 March 2015, 07:14:46 »
Any film applied to a surface has the potential to peel back off.
If that happened consistently, it might be OK, but since it will be random and spoltchy, it is sure to look bad.
- D Trump 2026-10-24
