Author Topic: Ditching QWERTY and staggered layouts  (Read 7542 times)
Offline william
« on: Fri, 27 February 2015, 06:02:46 »
I've always been a little perplexed by the popularity of QWERTY and staggered layouts, particularly with those who are worried about ergonomics, and I haven't really seen threads about it (though I haven't gone digging either).
So anyway, I'm curious to hear why people have stuck with the traditional layouts, or better yet, why you ditched them and what you've ended up with instead.
92164-0
This is on a Cherry RC80BM I just got for $36 off of ebay, but before that I was using a Cherry G86-63400 that I had bought for around $85 thinking it was mechanical. Don't regret the purchase though, it is a fun keyboard.
Before those, I had got an ergodox as my first mechanical, and pretty much hated it. Also one day I went to use it and the cord was all ****ing hot, but I wasn't bummed out enough to fix it. After using this key layout on a ****ty gaming keyboard for a while I decided it was time to get a point of sale keyboard and see if I could make it work for me. I wish I would have tried it in the first place, a regular grid is great. nothing goony/gimmicky. Just straight forward and fun.
Offline dusan
Re: Ditching QWERTY and staggered layouts
« Reply #1 on: Fri, 27 February 2015, 07:58:58 »
I'm a Dvorak typist but I don't think Dvorak layout is faster than QWERTY. It's just more comfortable.
Regarding physical layout, I'm building this matrix board, which is pretty similar to yours:
https://geekhack.org/index.php?action=dlattach;topic=64580.0;attach=81546;image
Topre Type Heaven | Filco Majestouch w/MX blue | CM Storm QF w/MX green | Asus Echelon w/MX black | Razer Tournament 2014 w/Razer green, Keychron K1 w/Gateron LP red | TypeMatrix 2030 | custom 6x16 ortho w/MX black | Atreus 44 w/Kailh box white & Gateron Pro yellow.
Offline vivalarevolución
« Reply #2 on: Fri, 27 February 2015, 08:16:09 »
You might be interested in these keyboards:
http://ortholinearkeyboards.com/
Offline MajorMajor
  • Mechanical Keyboard Enthusiast
    • Coding Supply
« Reply #3 on: Fri, 27 February 2015, 11:49:40 »
From what I have read, DVORAK can be quite a bit faster once you acclimate to it, which I think makes sense due to your fingers not needing to move as much. That being said, I'm 3 weeks into switching to DVORAK and I'm still around 30 WPM when I was at 90 WPM on QWERTY.
TKL / Clears / Dvorak / Flipped Space for Life / Best Programming Keyboards
Offline dusan
« Reply #4 on: Fri, 27 February 2015, 12:15:49 »
Can't wait to see if you can reach 100 - 120 WPM one day.
On Dvorak I'm at 80 wpm max, which is the same as my QWERTY performance the last time I could touch-type on it (20 years ago).
Offline william
« Reply #5 on: Fri, 27 February 2015, 14:12:35 »
You might be interested in these keyboards: http://ortholinearkeyboards.com/
I was looking at those the other day and thought they looked pretty cool. I think I'd have to come up with a pretty good gaming layer to feel like the size isn't too restrictive to me though. I suppose figuring stuff like that out is the funnest parts of using a micro board.
I haven't used a chorded layout before; is that what this is? I get a bit confused looking at these multi-layer layouts. I like the idea of laying out the numbers like that. There is something oddly satisfying about having things arranged in an way that is more logical.
Offline dusan
« Reply #6 on: Sat, 28 February 2015, 04:16:48 »
No it should be a normal keyboard, not a chorded keyboard. The extra function layer(s) are just a suggestion and should be fully user-programmable. Basically I've tried to be maximally compatible with the standard layout while giving users some additional comforts such as better hand separation, better wrist angle, better position for  Backspace, Enter, Esc and modifier keys, support for one-hand / any-hand navigating and editing, and a few extra keys which can be programmed for editing macros like copy, paste, undo etc.
« Last Edit: Sat, 28 February 2015, 04:34:50 by dusan »
Offline brimborion
  • Likes Matias Switches
« Reply #7 on: Sat, 28 February 2015, 04:27:47 »
Since my hands don't stick straight out of my chest like a Tyrannosaur, and I don't do home-row typing, it doesn't really matter if the keys are staggered or not.
I don't doubt if I typed "properly" it would be better to learn a more efficient layout, and it's likely that non-staggered keys are better as long as they face the same direction as my hands, but 90wpm has been enough for me for now.
Higher speeds are admirable and impressive, but not a goal at the top of the list.
Buckling Spring: 42H1292,  1391401, Unicomp Linux 101, Customizer 104 | Cherry Blue: Rosewill RK-9000, Das Keyboard S Pro | Cherry Black: Wyse/Link 840358-30| Rubber Dome: various Key Tronic, HHKB Lite, HHKB Lite 2, KB-8923, 71G4644 | Topre: Type Heaven | ALPS: Matias Mini Tactile Pro, 2xKBP V60
Offline steve.v
« Reply #8 on: Sat, 28 February 2015, 04:28:03 »
1. Ditched qwerty, learned Colemak, never went back.
2. Bought Ergodox.
3. One year in, going back to stagger keyboards.
I'm faster and more accurate on a staggered keyboard; I'm not sure why: possibly due to 15 years of usage. My hands move more laterally and uni when using an Ergodox. Colemak is probably the culprit. Qwerty could be better on ortho layout, who knows.
Offline batfink
« Reply #9 on: Sat, 28 February 2015, 10:42:47 »
2. Bought Ergodox.
I don't agree. One of the things Colemak is best at is avoiding same finger bigrams. On a matrix-like board, avoiding same finger bigrams is if anything, even more important, as the scope to use the non-standard finger is more restricted. Because Qwerty is so unoptimized, I would that it would be worse on a matrix board, whereas optimized layouts like Colemak should be better...
Offline Oobly
« Reply #10 on: Sat, 28 February 2015, 14:41:15 »
Do it properly, go ALL the way (like I did):
Vertical stagger instead of horizontal, split board, angled thumb key clusters and custom character layout :)
I don't think matrix layout is much of an improvement over normal horizontal stagger.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline william
« Reply #11 on: Sat, 28 February 2015, 16:32:50 »
my typing accuracy isn't nearly high enough to have the backspace where you do. I probably use it significantly more than enter still.
do you feel like your layout is ever restrictive? do you switch to any other board for certain activities, or are your layers close to perfect for you?
our layouts look like they have a lot of similarities.
Offline j03
« Reply #12 on: Sat, 28 February 2015, 17:13:43 »
I'm in my first week using Colemak on a Planck, and loving it!
Offline davkol
  •  Post Editing Timeout
« Reply #13 on: Sat, 28 February 2015, 17:20:01 »
2. Bought Ergodox.
Thumb keys are a part of the problem, because it's more difficult to actually float ones hands around the alpha keys with thumbs fixed in one spot. A high-alternation layout is the solution. I've been relatively unhappy with Colemak on ErgoDox ever since I became truly accustomed to the layout, while it's been perfectly fine on my thinkpad, typematrix and even random staggered mechanical keyboards.
