Author Topic: Black PBT keycaps for ALPS?  (Read 4536 times)
Offline ctm
  • Hello, world!
« on: Fri, 27 February 2015, 13:37:22 »
I recently got a KBP V60 with Matias switches and I really love the feeling of Matias switches! The only downside is it comes with thin ABS keycaps. I find some posts about harvesting PBT keycaps from vintage ALPS boards, but as far as I see they are all white or light grey keycaps, which does not look so great on my black keyboard. Also I think it's kind of wasteful to buy a keyboard just to harvest its keycaps. So is there anywhere I can get a set of black PBT ALPS keycaps? I am fine with both blank and legended ones.
Coming:
Ellipse Model F F62.
Offline jacobolus
Re: Black PBT keycaps for ALPS?
« Reply #1 on: Fri, 27 February 2015, 22:20:02 »
Get keycaps from an Apple Extended Keyboard II, and then dye them black.
Offline ctm
  • Hello, world!
« Reply #2 on: Fri, 27 February 2015, 22:24:29 »
That does not sound like an easy task though :(
Coming:
Offline Flyersfan1
  • Hi!
« Reply #3 on: Fri, 27 February 2015, 22:27:46 »
Massdrop is offering blank pbt dsa alps caps bundled with their infinity keyboard kit, but you must unfortunately also purchase a pcb/plate in order to get them.
Quote from: Photekq
Offline brimborion
  • Likes Matias Switches
« Reply #4 on: Fri, 27 February 2015, 22:40:15 »
http://matias.ca/60/pc/
This is supposed to have PBT caps if enough people commit to it, so Matias would be tooled up for them, at least for some key sizes. But it's hard to tell how many people have committed or when such a thing would ever ship, so I have been hesitant to take part.
Buckling Spring: 42H1292,  1391401, Unicomp Linux 101, Customizer 104 | Cherry Blue: Rosewill RK-9000, Das Keyboard S Pro | Cherry Black: Wyse/Link 840358-30| Rubber Dome: various Key Tronic, HHKB Lite, HHKB Lite 2, KB-8923, 71G4644 | Topre: Type Heaven | ALPS: Matias Mini Tactile Pro, 2xKBP V60
Offline jacobolus
« Reply #5 on: Sat, 28 February 2015, 05:26:05 »
It’s pretty easy. You just need to buy the dye, mix it up in hot water, and leave the keycaps in for a while. There are a bunch of guides on geekhack, if you do a search.
« Reply #6 on: Sat, 28 February 2015, 06:56:39 »
It would be difficult to find compatible keycaps for the bottom row. Older PC keyboards with Alps usually have 1.5u modifiers next to the space bar. The AEKII has a 1.5 and 1.25 unit modifiers and an Apple-specific keycap profile.
Most people use RIT dye for other colours than black, but black RIT dye does not always work very well with plastics. My results turned out brown.
Dylon or iDye might work better. You would have to look for, or experiment yourselves.
Offline ctm
  • Hello, world!
« Reply #7 on: Sat, 28 February 2015, 09:38:33 »
Interesting. I will look into using dyes.
Coming:
Offline ctm
  • Hello, world!
« Reply #8 on: Sat, 28 February 2015, 09:48:46 »
But another problem is that there don't seem to be any vintage ALPS board with all 1x1.25 modifiers in the bottom row.
Coming:
Offline jacobolus
« Reply #9 on: Sat, 28 February 2015, 11:19:05 »
That’s because 1.25 modifiers are the response to Windows 95, and by the mid-to-late 90s everyone selling Windows machines was trying to furiously cut costs wherever they could.
You’ll need to either be happy with ABS on the bottom row (e.g. using the stock keycaps or pulling spacebar-like shaped bottom row caps off a black AT101W), or replace them with PBT blanks from signature plastics. (They might have some 1.25u DSA caps in stock from MassDrop’s Infinity keyboards.)
« Last Edit: Sat, 28 February 2015, 11:30:27 by jacobolus »
