Author Topic: New 'Tt Type II' MX-compatible Plunger switch?  (Read 6453 times)
Offline exit
« on: Mon, 02 March 2015, 02:58:32 »
http://www.ttesports.com/productPage.aspx?p=188&g=ftr#.VPQlKvmUc0w
The COMMANDER uses Tt Type II Plunger Switches with Mechanical keycaps giving users an awesome tactile feel and clicks with each keystroke while giving responsive feeling like using a mechanical switch keyboard. This will improve gaming performance by giving users speed and responsiveness like never before.
Rubber dome is still rubber dome, but it looks different to standard rubber. This means that the keyboard is able to be customized with MX keycaps.
« Last Edit: Mon, 02 March 2015, 03:03:37 by exit »
Offline fknraiden
Re: New 'Tt Type II' MX-compatible Plunger switch?
« Reply #1 on: Mon, 02 March 2015, 03:05:35 »
hilarous
Offline Oobly
« Reply #2 on: Mon, 02 March 2015, 03:21:35 »
Yay!
Rubber dome with MX compatible stems... And a non-standard bottom row = pointless
And yes, it IS standard rubber dome. The "click" they mention is simply the slider hitting the top of the casing on key release. They'll probably still get some extra sales out of this marketing BS, though. I wish the general public cared more about what they spent their money on.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline FoxWolf1
  • 154
« Reply #3 on: Mon, 02 March 2015, 11:07:27 »
Oh, they're rebranding that one now? Okay.
Kind of a shame though...if they wanted to pick something with an MX-compatible stem over rubber domes, there are nicer-looking choices.
« Reply #4 on: Mon, 02 March 2015, 16:13:23 »
Someone hurry up and let BTC know they can make a comeback as a gaming brand.
