Author Topic: Fix a warped PCB?  (Read 3724 times)
Offline Jixr
Fix a warped PCB?
« on: Mon, 02 March 2015, 09:30:30 »
Is there any way to fix a warped PCB?
I have a 60% keyboard pcb that has a pretty noticeable bend in the backspace area, even with a steel plate, it still bends quite a bit.
Is there any good way to fix a warped pcb?
It could also be the way its mounted in the case, possibly the screws are too tight.
But i'm at work and just noticed it, and don't have a screwdriver handy.
Offline plegnic
  • Treble Booty. Bass Guitar.
Re: Fix a warped PCB?
« Reply #1 on: Mon, 02 March 2015, 09:37:02 »
Check the screws and the way it's mounted first. The PCB itself is usually made of some kind of fiberglass/epoxy/etc. and can't really be bent back into shape or anything.
Planck MIT layout [MX Clears] (in-progress) | QuickFire Storm TK [MX Brown] | Poker II [MX Blue]
