Author Topic: Topre compared to MX Clears  (Read 3536 times)
Offline Profoundsoup
« on: Mon, 02 March 2015, 12:54:11 »
How do each of these switches compare? I have never used a topre switch so Im curious!
Re: Topre compared to MX Clears
« Reply #1 on: Mon, 02 March 2015, 12:55:40 »
They don't really nothing MX directly compares to anything topre.
Offline strict
  • TKL Zealot
« Reply #2 on: Mon, 02 March 2015, 13:05:36 »
Topre is hard to compare to MX.
From a tactility standpoint, 55g Topre feels more tactile to me. Weighting wise, 55g Topre feels slightly lighter than stock MX Clears.
« Reply #3 on: Mon, 02 March 2015, 13:37:12 »
Topre more tactile than clears!??! That clears have a huge bump from what ive used of them
Offline Defect
« Reply #4 on: Mon, 02 March 2015, 14:24:07 »
There's lots of threads on this, but basically'
Topre = collapsing rubber dome.  Break point of resistance and it falls with no support
MX = plastic bump against metal contact leaf, pushed up by spring.
MX will have more support ramping as you press down due to how springs work, vs Topre just collapses.
People complain MX feels gritty (until broken in for over a year).  55g Topre is fatiguing over time as the bottom out can be harsh, even though it is slightly cushioned by the rubber dome.
Stronger fingers dislike the 55g Topre due to the collapse, but with a light touch it is quite enjoyable.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #5 on: Mon, 02 March 2015, 14:25:38 »
Topre is like rubbing the shoulder of a supermodel and cherry Mx is like rubbing the shoulders of your hot coworker.
« Reply #6 on: Mon, 02 March 2015, 14:28:34 »
Both get you sued for sexual harassment?
Offline ideus
  • Björkö.
« Reply #7 on: Mon, 02 March 2015, 14:29:48 »
This is a clear and objective explanation.
Offline GL1TCH3D
« Reply #8 on: Mon, 02 March 2015, 14:30:01 »
Not if you paid the supermodel.
Offline ideus
  • Björkö.
« Reply #9 on: Mon, 02 March 2015, 14:31:01 »
Neither if you married your co-worker. :))
Offline tbc
« Reply #10 on: Mon, 02 March 2015, 15:03:32 »
what if your coworker is a supermodel?
« Reply #11 on: Mon, 02 March 2015, 16:06:43 »
Wasn't there a thread like this yesterday? Oh... that was about Matias Quiet. sorry.
I think that Topre, Matias Quiet Click and Ergo Clear are somewhat comparable in force-per-travel, where the tactile bumps are etc.. But they can't be compared in smoothness. Topre are smoother than any other stock switch, for sure.
I haven't tried 55g Topre, but I find MX Clear to be more tactile than 45g Topre. Stock MX Clear have stronger springs that cushion the strokes so that you won't have to bottom out as often - and that makes them feel less heavy for me  than 45g Topre that I always bottom out.
Then you would be a model too, and you wouldn't be here typing.
« Reply #12 on: Mon, 02 March 2015, 16:12:30 »
The coworker is more satisfying because you at least have a chance with her?
Offline ideus
  • Björkö.
« Reply #13 on: Mon, 02 March 2015, 16:13:59 »
The supermodel looks good in pictures only.
Offline GL1TCH3D
« Reply #14 on: Mon, 02 March 2015, 16:31:36 »
Then you just get fired for sexual conduct at work ;(
Offline paicrai
  • mindblank
« Reply #15 on: Mon, 02 March 2015, 16:37:12 »
topre killed jfk
THE FEMINIST ILLUMINATI
