Author Topic: 120 HZ on HDMI/DVI or HDMI/DP?  (Read 2890 times)
Offline Naweo
« on: Tue, 03 March 2015, 06:31:31 »
Heya, my BENQ monitor supports 144 HZ and my samsung monitor supports 120 hz, as worked with 2x dual-d DVI ports on my 760 card.
Now that I use 980, I would like to know if it is possible to run 120 and 144 hz on a DVI/HDMI combo or DVI/DP or HDMI/DP combo. Also, I would like to use a 3rd monitor but I do not need more than 60 hz for that.
Is it possible to run 1x HDMI, 1x DP (with adapter since none of my monitors has a DP I think) and 1x DVI, with at least 2 of them running 120/144 hz? thanks!
