Author Topic: Question for HHKB PRO 2 Type "S" and non Type "S" owners  (Read 1992 times)
Offline strain67
« on: Tue, 03 March 2015, 12:03:33 »
Could you take a dark grey pro 2 and a white type 2 and just switch the case and key caps to make a dark grey type s? I really like the look of the dark grey and the type S is so recommended that I'm considering doing that and selling the white one after the switch. Thanks!
Offline exitfire401
  • The Force is Re/\l
Re: Question for HHKB PRO 2 Type "S" and non Type "S" owners
« Reply #1 on: Tue, 03 March 2015, 12:07:27 »
It requires removing all of the sliders and the dampening material from the type-s as well. Type-s sliders are a little bit longer to deal with the reduced travel. So you can, it's just a bit of work.
Offline strain67
« Reply #2 on: Tue, 03 March 2015, 12:12:05 »
I may just keep it in white then. I think that the white/gray looks nice but I'm just not sure if I would actually like it in person and how it would kind of look weird with everything else i have being black. Thanks for the info!
Offline cheebs
Colored keycaps do wonders for the appearance of the white HHKB. Get yourself the blue esc red control kit, and/or some of those orange/green colored modifiers on elitekeyboards.com
Offline trizkut
« Reply #4 on: Wed, 04 March 2015, 12:58:27 »
The other alternative is applying one of the several available dampening mods on the pro 2 (dental bands, punched rubber, or flattened landing pads).
Offline exitfire401
« Reply #5 on: Wed, 04 March 2015, 13:01:58 »
Punched rubber or nothing. It doesn't affect travel and dampens as much as everything else
Offline spiceBar
    • ChessTiger.com
« Reply #6 on: Wed, 04 March 2015, 15:40:16 »
Just for your information, the flattened (ironed) landing pads mod does not affect the travel/feel AT ALL.
