Author Topic: Leopold FC200R switch change  (Read 1254 times)
Offline Dionysos
« on: Wed, 04 March 2015, 15:58:06 »
I have an old Leopold w/cherry blues. Is it possible to switch those out for the Matias Quiet Clicks? Matias is plate mounted, and the cherry switches are also plate mounted. I didn't know if the pin configuration was different.
Offline Dionysos
Re: Leopold FC200R switch change
« Reply #1 on: Wed, 04 March 2015, 16:02:25 »
I guess I would need the keycaps for the matias switches as well.. IDK if those are available somewhere..
« Reply #2 on: Wed, 04 March 2015, 16:24:47 »
Unless something big has changed, Matias switches do not fit into the footprint of Cherry switches.  The pins are different.
