Author Topic: What is OEM keycaps?  (Read 3473 times)
Offline okaydoke
« on: Wed, 04 March 2015, 23:49:58 »
Hi All,
what's the different between Cherry's and OEM keycaps? I often saw ppls said OEM keycaps is a little bit higher than the Original Cheery one. Are there any other different beside the height?
Thanks,
Re: What is OEM keycaps?
« Reply #1 on: Thu, 05 March 2015, 00:01:48 »
OEM is much taller.
OEM = original equipment manufacturer, and refers to the (often cheap) keycaps that the keyboard manufacturer puts on a new keyboard in the factory.
Offline okaydoke
« Reply #2 on: Thu, 05 March 2015, 02:06:48 »
OEM is much taller.
Thanks rowdy  ;)
Offline jacobolus
« Reply #3 on: Thu, 05 March 2015, 02:34:30 »
Offline drewba
« Reply #4 on: Thu, 05 March 2015, 12:10:58 »
Offline Firebolt1914
  • POM Overlord
« Reply #5 on: Fri, 06 March 2015, 21:10:00 »
Aren't there different OEM profiles, or is it all a standard?
Offline hking0036
« Reply #6 on: Fri, 06 March 2015, 21:42:00 »
There's probably variation but they're all in the same general ballpark, I think.
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
