Author Topic: completely new to building custom keyboards and need a little help  (Read 3740 times)
Offline evangs
  • TheVan
I am taking on my first custom keyboard project and am super excited, but am having a bit of trouble.
My first question is, what kind of diodes do I need and where can I get them?
second question is, what are the non- wire cherry stabilizers called and where can I get them?  Going to be plate mounted switches if that matter.
thanks
Offline phishy
Re: completely new to building custom keyboards and need a little help
« Reply #1 on: Thu, 05 March 2015, 11:12:02 »
You need any variant of the 1N4148 switching diode.  Lots of places online carry them but you can also source them from radioshack for 1.99 per 10 pack.  And I think the stabilizers you are talking about are the actual cherry stabilizers but good luck finding them.
Offline evangs
  • TheVan
« Reply #2 on: Thu, 05 March 2015, 11:16:20 »
thanks!
what's the deal with the cherry stabs? why are they so hard to find?
Offline Dihedral
  • Mostly Harmless
« Reply #3 on: Thu, 05 March 2015, 11:42:09 »
1.99 per 10 pack
which is about an order of magnitude or two more expensive then if you buy online.
Offline evangs
  • TheVan
« Reply #4 on: Thu, 05 March 2015, 11:45:38 »
1.99 per 10 pack
I picked up 100 of them on amazon for like 6 bucks
Offline Sygaldry
  • Edema Ruh
« Reply #5 on: Thu, 05 March 2015, 11:48:17 »
http://www.gonskeyboardworks.com/10-stabilizers
Shipping might be expensive but this might be your best bet for now.
null
Offline evangs
  • TheVan
« Reply #6 on: Thu, 05 March 2015, 11:55:53 »
Those all say pcb mount.  I will be hand wiring the matrix and won't have a pcb, will those still work?  also those all look like they have wires?
« Reply #7 on: Thu, 05 March 2015, 12:03:38 »
I'm not sure what you mean by non-wire stabilizers? All stabilizers have wires. Cherry plate mount stabs have the wire hidden under the plate.
Offline evangs
  • TheVan
« Reply #8 on: Thu, 05 March 2015, 12:16:57 »
ahhh ok, that makes sense then.  Sorry I am a total noob
Offline phishy
« Reply #9 on: Thu, 05 March 2015, 12:18:17 »
http://www.wasdkeyboards.com/index.php/products/keyboard-parts.html probably the cheapest bet for stabs.
« Reply #10 on: Thu, 05 March 2015, 13:16:52 »
No need to be sorry for being a noob. We all were, at one point. :)
What you are looking for are called Cherry plate mount stabilizers, or "MX Leveling Mechanism Kit." Cherry part numbers to search for are G99-0224, G99-0225, G99-0226, or G99-0379, depending on the size of the wire you need. Or you can always bend your own wire to spec, and use any of those kits.
When you create your switch mounting plate, you want to use the plain square holes for your switches. And use Cherry (only) stabilizer holes, if you never plan to use Costar stabilizers.
Offline evangs
  • TheVan
« Reply #11 on: Thu, 05 March 2015, 14:41:01 »
Perfect! Thanks so much, this is exactly what I was looking for
Offline evangs
  • TheVan
Offline geniekid
« Reply #13 on: Thu, 05 March 2015, 16:53:01 »
got the stabilizers from http://www.alliedelec.com/cherry-g99-0224/70386219/
G99-0224 is the right part number but the picture on that site shows PCB-stabs so hopefully the picture is wrong!
« Reply #14 on: Thu, 05 March 2015, 16:57:14 »
Yes, the picture is wrong. I ordered some of those from Allied and got the correct plate mount stabs. :)
