Author Topic: Project Zealio - 62g/65g/67g Purple "MX Clear" Switch in transparent housing  (Read 770419 times)
Offline Zeal
  • * Moderator
    • Zeal Generation Inc.
Re: Project Zealio - 62g/65g/67g Purple "MX Clear" Switch in transparent housing
« Reply #750 on: Thu, 05 January 2017, 23:36:53 »
I have Zealios 78g tactile on my ergodox but few switches make some noise. Do you have any advices for lubbing?
I saw Ripster's photo serie (http://imgur.com/a/lhLqo) but I'm living in France and most of products don't exist here...
For the moment I have this : http://fr.rs-online.com/web/p/graisses/0520181/
I believe you also sent me an email, but I'll reply here as well.
I'd personally recommend picking up some the GH V4 thick lube on my site. It's a custom blend of Krytox specifically made for tactile switches/springs/stabilizers. If you're looking for something local, try finding a thick lube containing ptfe at the very least.
Offline Heliobb
« Reply #751 on: Sat, 14 January 2017, 11:17:35 »
Thanks a lot !
Novatouch TKL - Leopold FC660C - PBT my life.
Offline mk-lovers
    • MK Lovers Store
« Reply #752 on: Sun, 22 January 2017, 08:10:18 »
Zealios are simply mesmerizing.
Offline lunr
« Reply #753 on: Thu, 26 January 2017, 13:53:34 »
r5 soon? there were some 67g in stock yesterday when i checked, now it's all gone :(
Offline Zeal
  • * Moderator
« Reply #754 on: Thu, 26 January 2017, 14:09:42 »
Yeah, R5 will launch end of the month/early Feb. Stay tuned.
