Author Topic: Project Zealio - 62g/65g/67g Purple "MX Clear" Switch in transparent housing  (Read 784193 times)
Offline KaminKevCrew
Re: Project Zealio - 62g Purple "MX Clear" Switch in transparent housing
« Reply #500 on: Sat, 15 August 2015, 22:47:03 »
Woops, forgot to show this pcb shot.
Lots of interesting things can be done...
Is that PCB fully programmable? Like, including media keys? If it is, can I buy it at the time that the GB happens? Because I would love to...
Offline Zeal
  • * Moderator
    • Zeal Generation Inc.
« Reply #501 on: Sat, 15 August 2015, 22:51:11 »
The PCB isn't part of the GB. I just picked out one of my unassembled keyboards from my pile and did a photoshoot. :)
« Reply #502 on: Sat, 15 August 2015, 23:00:06 »
Oh well, guess I'll have to find a board for myself then :P (maybe I'll go and design one!!! though the first few(hundred) would suck, since I know nothing about it at this point...
Offline SadisticReap
« Reply #503 on: Sun, 16 August 2015, 00:37:31 »
I am so jumping in on this GB when it is available. These along with the TK-78 are gonna make a beautiful DD for me.
Offline Ngt
« Reply #504 on: Sun, 16 August 2015, 03:14:57 »
As I asked whether they would be lubed or not in the mail thread I come back here. Do you think it would be possible to include lube in this GB as well like Krytox (don't remember the exact reference)?
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #505 on: Sun, 16 August 2015, 03:16:14 »
Aww yeeee
Offline maximusprimate
    • maxben.net
« Reply #506 on: Sun, 16 August 2015, 09:17:43 »
Not sure if this has been asked yet, but is there any chance of selling just the sliders (sans spring and housing) for a smaller price?  If so, how do you think they would fit in a Cherry/Gateron housing?  I'll probably end up getting a bunch of these switches either way, but if I could save a buck I would.
Offline Zeal
  • * Moderator
« Reply #507 on: Sun, 16 August 2015, 09:32:11 »
I still have a few GH lube kits left over. I'll definitely be asking mkawa about supplying some more Krytox for these switches.
Aww yeeee
Bon voyage. :)
The sliders will fit in Cherry/Gateron housings no problem, but Gateron wouldn't want to be selling the sliders individually. They prefer manufacturing products as a "package".
Offline dante
« Reply #508 on: Sun, 16 August 2015, 09:37:09 »
Help me out here - Gateron's are already smooth enough.  Why add lube?
Offline Zeal
  • * Moderator
« Reply #509 on: Sun, 16 August 2015, 09:38:22 »
So you can experience this
Like I said, if the user thinks it's smooth enough, then by all means this will replace all the tedious work required to make ergo clears. But for the enthusiasts that want the best of the best, they'll open the switches up and lube em. :)
« Last Edit: Sun, 16 August 2015, 09:40:19 by Zeal »
Offline dante
« Reply #510 on: Sun, 16 August 2015, 10:00:13 »
Yes but some typing will help wear down the stems as well.  If these get put in an "end game" keyboard that is used 8-10 hours a day every day the results should be fairly close after a year or so.
I just think it is confusing to folks after hearing how smooth Gaterons are compared to their Cherry counterparts and yet people are still adding lube.  Sounds similar to Chinese hot peppers - can't get enough I suppose. :)
Offline jerue
  • (Whenever that happens :P)
« Reply #511 on: Sun, 16 August 2015, 12:05:53 »
These need to go in my Poker 2. Can't wait for the GB!
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Last Edit: Sun, 16 August 2015, 13:21:32 by pichu23 »
Offline strict
  • TKL Zealot
I'm prepared to replace 2 keyboards worth of clear switches for these. My biggest complaint with clears has always been the scratchiness, if these are really that smooth I will be buying lots of them!
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
I will be excited to see how these compare to worn clears. They are currently my favorite switch
Offline awhitedev
« Reply #515 on: Sun, 16 August 2015, 19:35:32 »
Will lube be available for purchase with this buy?
Offline ika
« Reply #516 on: Sun, 16 August 2015, 19:39:05 »
So what's the deal with the RGB LED compatibility? Four holes in the switch bottom? Do 3mm (or whatever) in-switch RGB LEDs exist? What else is required for full control of the "RGB" part, an LED driver and support baked into the PCB? Was the 4-pin LED pictured by Zeal, the ones he said he would be stocking after PCB support is added, a 1.8mm LED?
« Last Edit: Sun, 16 August 2015, 21:15:43 by ika »
Offline DrHubblePhD
  • I am star stuff
« Reply #517 on: Sun, 16 August 2015, 19:59:56 »
I think Zeal would like to stop answering the same questions multiple times, please refer to the past couple of pages or search the thread first before posting a question  :thumb:  :p
Offline njbair
    • nickbair.net
« Reply #518 on: Sun, 16 August 2015, 20:14:47 »
You sound like someone who's run a GB before.
My boards:
« Reply #519 on: Mon, 17 August 2015, 02:10:18 »
It might be nice if the first post included a FAQ? I know that when I asked my first questions, I was in a bit of a rush, so I didn't want to read through the whole thread... (I have now though, so I'm all caught up!)
Offline Ngt
« Reply #520 on: Mon, 17 August 2015, 02:11:25 »
Offline Sed8op8
  • Keyboard Padawan
THIS^^^^ Very excited for these and will be buying some regardless of the outcome however due to gatetrons already smooth feel I'm very interested to see how these compare to a nicely lubed cherry ergo with identical weighted springs.
I'm not sure if comparing a new switch to worn clears would be exactly fair(unless it was a worn zealios switch) but I'm interested all the same  :eek:
Zeal or any other reviewers out there care to lube some zealios up and compare them to there cherry ergo brethren !
Thanks everyone involved !!!!!
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #522 on: Mon, 17 August 2015, 07:08:02 »
But why male models?
GON NerD TKL DTA Edition
Offline Zeal
  • * Moderator
« Reply #523 on: Mon, 17 August 2015, 14:08:33 »
A special PCB will be designed to support RGB LEDs. No, the 4-pin LED I showed in the previous post is not an 1.8mm LED.
1.8mm leds look like this
Offline Zeal
  • * Moderator
« Reply #524 on: Mon, 17 August 2015, 14:19:25 »
Ok Class, time for some keyboard science. :))
When I first took this comparison shot, it appeared that Gateron Purples had less of an "indent" during resting position of the switch.
But I was telling myself it's the darker colour & lubricant giving off that illusion.
So.....Today I cut off a leg... A Cherry Clear leg. :eek: (Excuse the dust, it took around 30minutes to have the legs aligned. :( Lots of touching involved)
Crop:
Purposely moved the clear leg a bit back to compare the bump & slopes. Mind you, it's very hard to make fine adjustments by hand when you're dealing with fractions of a millimeter!
Crop (Oh my, look at those mini bumps on the clear stem :)))
In Conclusion, the slopes and bumps are the same. The plastic is just that much smoother that I will most likely be upping the weight to replicate "vintage" ergo clears.
Just for fun. Sorry, Cherry Fans.
« Last Edit: Mon, 17 August 2015, 14:21:25 by Zeal »
« Reply #525 on: Mon, 17 August 2015, 15:35:15 »
I'm really liking the looks of those so far. Let us order them already!!! :P
Offline ika
« Reply #526 on: Mon, 17 August 2015, 17:07:55 »
Personally I would like to stick with the 62g weight, or even a lighter weight, to make it closer to Browns with a bigger bump. Would be great if both switch weights would be available, but not sure how feasible that is.
Offline dante
« Reply #527 on: Mon, 17 August 2015, 19:32:47 »
This thread needs less masturbation - more order taking.
Offline awhitedev
« Reply #528 on: Mon, 17 August 2015, 19:51:07 »
I think sometimes a heavier spring results in a better feeling travel. I'm not talking super heavy or anything but 65-72g... in that range. you can really appreciate the smoothness. When it's too light the key bottoms out too easily and you can't really feel just how smooth it was. Just one man's opinion anyways. \_(ツ)_/¯
Offline Ngt
« Reply #529 on: Tue, 18 August 2015, 03:26:24 »
Perhaps we could order the stem, housing and springs separately for those willing to have a different weight. Would it be doable Zeal?
Offline wlhlm
« Reply #530 on: Tue, 18 August 2015, 04:00:28 »
Offline Ngt
Thanks but then will gateron be shipping the switches with the gold plated springs or will Zeal perform the swap by himself? In the last case perhaps he can offer not to swap them and sell springs on the side so people could pickup the weight they'd want.
Offline azhdar
  • Praise the AZERTY god
« Reply #532 on: Tue, 18 August 2015, 04:05:52 »
lol no Zeal ain't gonna swap each spring himself. Gateron has the springs.
Azerty Propagandiste
Offline Ngt
Fair enough. I wonder if he could offer different spring weight for the buy but I guess it would be harder to meet MOQ then if there is one.
Offline strict
  • TKL Zealot
Without having felt them, I would lean toward sticking with 62g. When I was playing around with ergoclears I thought that spring weight gave the best feel. I'll pretty much trust whatever zeal decides though  :thumb:
Offline Sed8op8
  • Keyboard Padawan
62g springs are the stereo typical ones for ergos and don't get me wrong I love that weighting however 65g and 67g are my faves. It's not much of a difference but I've found those to feel a little smoother with the increased weight. As strict said though I'll be happy with zeals choice! So much hype  :thumb:
Offline BigTinz
« Reply #536 on: Tue, 18 August 2015, 15:36:28 »
65g tactile plz.
« Reply #537 on: Tue, 18 August 2015, 17:40:55 »
First impressions
A1 = 62g Linear Zealio
B1 = 62g stock Zealio
B2 = 65g stock Zealio
B3 = 67g stock Zealio
C1 = 62g lubed Zealio
C2 = 65g lubed Zealio
C3 = 67g lubed Zealio
A1 = Nope. Too light. Feels nice and smooth like a linear Gateron though
B1 = First time I tried a 62g Clear that wasn't sticky and didn't have any issues.
B2 = See above
B3 = Reminds me of my worn MX Clears at work. Well...at least the weight.
C1 = The bump feels more connected. Like it's one motion instead of two. Starting to convince me that previous 62g modded clears I've tried were a bust compared to this.
C2 = Might be my new favorite modded MX-mount "Clear" switch
C3 = Ugh I can't pick between this or C2
First thought I had was that all the modded MX Clears I tried were supposed to feel like this. Other than stock MX Clear and Panda Clears. 62g, 65g, and 67g never felt so good.
I'll do a better review later. I've got like 10 minutes of play time with these switches so far. I'm starting to feel more and more that Cherry MX is meh. Gateron and Greetech are becoming more interesting to me the more I play with them.
Offline Zeal
  • * Moderator
« Reply #538 on: Tue, 18 August 2015, 17:51:14 »
First impressions
C1 - Agreed, feels like one smooth motion. No bumpy roads or drops. Perhaps a new replacement for vintage browns? (haven't tested v. browns myself)
C2/C3 - Exactly my thoughts on 65g vs 67g lubed Zealios. Very tough decision... May be favouring 65g a tiny bit more though.
Offline awhitedev
« Reply #539 on: Tue, 18 August 2015, 18:40:51 »
I really like my lubed Panda Clears but I always thought they were a tad too heavy. How do these stack up?
Offline Karura
  • SKidata life.
« Reply #540 on: Tue, 18 August 2015, 19:23:51 »
First impressions
B2 = See above
Nice writeup. I definitely like lubed 65g the best from my tests, but would prefer to have 67g in my personal keyboard due to preferring 67g springs. 67g feels more like proper worn-in clears with a smoother, less pronounced bump.
« Reply #541 on: Tue, 18 August 2015, 19:39:03 »
I still really like Panda Clears but I think the 67g would fit you better. Give me a little while to play with these switches. I'll make a Panda Clear outta these and report back.
« Reply #542 on: Tue, 18 August 2015, 22:15:10 »
Probably Cherry sticking with the tried and tested 6 or 7 standard switch types, and the newcomers experimenting with different options.
Large established keyboard manufacturers with established relationships with Cherry will most likely stick with Cherry, but smaller players might very well seek the Gaterons and Greetech switches to provide something new to their clients.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #543 on: Wed, 19 August 2015, 05:14:03 »
First impressions
B2 = See above
65/67g seems like a sweet spot for this switch. :O
Gah, the wait  :-X
Offline Sed8op8
  • Keyboard Padawan
« Reply #544 on: Wed, 19 August 2015, 07:08:25 »
First impressions
B2 = See above
Gah, the wait  :-X
First impressions
B2 = See above
thank you captn this is really what I was hoping for. Looks like I'll be ordering 110-120(not sure the package size for these) of the 65g and 67g ! I need some for an 1800 I have incoming and the mira
« Last Edit: Wed, 19 August 2015, 09:01:47 by Sed8op8 »
Offline theanyday
  • love love love
« Reply #545 on: Wed, 19 August 2015, 08:40:35 »
First impressions
Seems like we might need a custom 66g spring in these bad boys.  :-X
MIRA SE | White Fox w/ 67g Zealios | POK3R w/ Blues | K70 w/ Browns | Planck w/ Greens | NovaTouch TKL
Offline livingspeedbump
    • KeyChatter
« Reply #546 on: Wed, 19 August 2015, 14:31:54 »
https://www.keychatter.com/2015/08/19/review-project-zealio-switches/
There are my initial thoughts after testing the switches out.
I was nothing but impressed with the switches. At the end of the day my favorite Cherry MX switch was greatly improved. The stems are indeed not as tight as Cherry Clears, so no more worrying about ripping the  stems out when removing keycaps. They were all extremely smooth, without any grittiness at all. Also, purple!, 'nuff said.
As far as individual switches go (62g, 65g, 67g) I think it all just comes down to personal preference. There isn't a clear "best" switch of the lot. My personal favorite was by far the 67g switch though. It was the most refined feeling MX switch I've ever used. I wouldn't compare it to Topre directly, but as a huge Topre fan the 67g switch really stuck out for me. I will definitely be throwing those into my Mira.
The main thing really is that there was nothing about the switches that would make me hesitate on jumping in on the group buy for a few hundred of each right now. I had no issues with the switches or the Clear RGB tops at all. ZealPC, well done sir, well done  :thumb:
<- My Collection (so far)
    • KeyChatter
« Reply #547 on: Wed, 19 August 2015, 14:33:38 »
I'm right there with you.
Offline Zeal
  • * Moderator
« Reply #548 on: Wed, 19 August 2015, 15:21:52 »
I'm glad I'm not the only one that thought 67g felt like it had a higher positioned bump and was reminded of Topre :))
Re: RGB Tops, they will come stock on Zealios. The test samples just didn't have them installed by default :-[ It also prevents catching on thicker caps such as GMK, etc.
Thanks again for sharing first impressions!
« Last Edit: Wed, 19 August 2015, 15:24:00 by Zeal »
Offline potatowire
« Reply #549 on: Wed, 19 August 2015, 15:30:30 »
These initial impressions have convinced me. I'm in for at least 330 (67g non-lubed, if I had to choose now).
I can't wait.
