Author Topic: Project Zealio - 62g/65g/67g Purple "MX Clear" Switch in transparent housing  (Read 787112 times)
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: ? (Introducing Project Zealio~)
« Reply #250 on: Wed, 01 April 2015, 21:32:51 »
All of the image that you need to know
Aww man...and I just finished it too  :p
Yours is a lot better than mine anyways
Offline FrostyToast
  • Litshoard
« Reply #251 on: Wed, 01 April 2015, 21:35:38 »
Outside of the fact that it looks to have a gold spring inside with gold contacts, I'm not getting the hype...unless there's an SMD LED module in the post in the middle.
Soooooo
There is a little more hype left that you guys haven't figured out.
This last bit that he hasn't revealed is much more than just "reddit relevant".
I'll leave you to figure out the hype.  :thumb:
Quote from: elton5354
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #252 on: Wed, 01 April 2015, 21:37:41 »
Soooooo
Well in the picture there is something red :<
Offline njbair
    • nickbair.net
« Reply #253 on: Wed, 01 April 2015, 21:40:09 »
Soooooo
Yeah you're right. It's red and there's a spirally thing.
My boards:
Offline Latin00032
« Reply #254 on: Wed, 01 April 2015, 21:49:46 »
I don't understand what the picture means.
« Reply #255 on: Wed, 01 April 2015, 21:52:08 »
Switch has LED in the middle and lights up when it's depressed.
Offline HTN47
  • Mr. SoCal
« Reply #256 on: Wed, 01 April 2015, 21:57:57 »
Could this be the famous RGB switches with LED inside the switch similar to that from the Corsair RGB keyboards?
whoops nub posted the answer  :D
What is love.... Baby don't hurt me... No more!!
Offline njbair
    • nickbair.net
« Reply #257 on: Wed, 01 April 2015, 22:04:06 »
Is that really what this is? If it's an RGB LED where are the 4 extra leads?
My boards:
Offline Zeal
  • * Moderator
    • Zeal Generation Inc.
« Reply #258 on: Wed, 01 April 2015, 22:29:06 »
Offline Cottonsox
« Reply #259 on: Wed, 01 April 2015, 22:31:35 »
 :eek:
« Reply #260 on: Wed, 01 April 2015, 22:32:08 »
Where's my mystery package?
Offline KnivesM
« Reply #261 on: Wed, 01 April 2015, 22:34:12 »
Awesome, Cherry RGB  :eek:
Others
Offline njbair
    • nickbair.net
« Reply #262 on: Wed, 01 April 2015, 22:36:54 »
How does this work? Can you set the color or does it just cycle through them all the time?
My boards:
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #263 on: Thu, 02 April 2015, 00:43:40 »
Zealio is love~ Zelio is life ~
I've got one. I've felt it. I've touched it. I've used it.
I love it~ For a factory new switch, it's dank, son. Beats any factory new MX switch.
I'm hype. Sign me up for an entire batch, plox.
I took these photos earlier tonight~ Sorry for some blur~ They were rushed :(
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #264 on: Thu, 02 April 2015, 00:50:37 »
Neato!!!
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #265 on: Thu, 02 April 2015, 00:52:00 »
Neato!!!
They're neato alright!!! I can't wait to get more...
  • Kitteh Overlord
  • Say WHAAT...
« Reply #267 on: Thu, 02 April 2015, 00:59:51 »
Neato!!!
You only got one right now??? what a tease...  :))
I'm not a huge LED fan, but if you get them set up right... could be legit... Would be real
sick for capslock and numpad setup...
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #268 on: Thu, 02 April 2015, 01:03:17 »
I'm with you, mane. I don't own a single backlit keyboard because I honestly don't really care for them. However, a well EVENLY lit keyboard under the keycaps would look dayum fine. Even if not backlit, these clear switches would look mighty fine too.
Neato!!!
« Last Edit: Thu, 02 April 2015, 01:17:50 by VesperSAINT »
Offline azhdar
  • Praise the AZERTY god
« Reply #269 on: Thu, 02 April 2015, 01:30:38 »
Same question.
Also who's the manufacturer?
Azerty Propagandiste
Offline Zeroo
« Reply #270 on: Thu, 02 April 2015, 04:31:14 »
Same question.
Better be gateron for optimal girth
Offline Dihedral
  • Mostly Harmless
« Reply #271 on: Thu, 02 April 2015, 07:06:09 »
I would want some of these, but only with Clear switches which Gaterons do not have an equivalent for.
Offline FrostyToast
  • Litshoard
« Reply #272 on: Thu, 02 April 2015, 07:10:30 »
Same question.
Those LEDs just cycle through all of the colours unfortunately.
I don't know of any 2x3x4 or 1.8mm LEDs which allow you to control the colours.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #273 on: Thu, 02 April 2015, 22:01:31 »
Ahaaa! So it was RGB :P really interested in your project Henry. Will drop by here often !
Offline feizor
« Reply #274 on: Tue, 14 April 2015, 07:27:05 »
Same question.
I think the point of the video was not the RGB led but infact the totally see through transparent switch housing.
Offline wakko
« Reply #275 on: Mon, 27 April 2015, 00:05:50 »
Someone asked this earlier, do you program the color or they change somehow? Not really into keyboards that light up like Christmas trees.
NOOB
KUL ES-87
Offline fi0x
« Reply #276 on: Sat, 06 June 2015, 09:01:20 »
I was like Gateron Clear switch tops with gold springs and gold contacts?
Awesome.
And then I was like wait...
Cherry MX Clears in a "clear" switch casing with gold springs and contacts?
Even Better.
 :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb:
Now to prepare my wallet...
Replace Starlight Breaker with Project Zealio and replace the first 'you' with 'your wallet'.
Thank you Zeal!
« Last Edit: Sat, 06 June 2015, 09:25:50 by fi0x »
~I̶ ̶a̶m̶ ̶n̶o̶t̶ ̶a̶ ̶k̶e̶y̶b̶o̶a̶r̶d̶ ̶g̶e̶e̶k̶ ̶(̶I̶ ̶w̶o̶u̶l̶d̶ ̶l̶i̶k̶e̶ ̶t̶o̶ ̶t̶h̶i̶n̶k̶ ̶I̶'̶m̶ ̶o̶n̶e̶)̶ I am a keyboard geek~
Offline adamski07
  • adamskimodz|fudorekz12
« Reply #277 on: Fri, 17 July 2015, 20:32:08 »
This is awesome! I'll try to get a spot for Mira and hoping to be in the first 57. I am also hoping that Winkeyless remembers my suggestions of having a better controller for their boards. It would be nice if we can set any color we want for each RGB LED. Unfortunately, their current controller can't do this yet. Only few different RGB modes and just the on board's led.
Offline njbair
    • nickbair.net
« Reply #278 on: Fri, 17 July 2015, 23:25:59 »
AFAIK the RGB channels on these switches are not individually addressable, so they really won't help you towards your goal of fully-customizable backlighting.
My boards:
Offline Zeal
  • * Moderator
« Reply #279 on: Wed, 22 July 2015, 16:27:06 »
Fresh protos soon™
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #280 on: Wed, 22 July 2015, 17:15:03 »
 :blank: There are no words.  :blank:
Offline Zeal
  • * Moderator
« Reply #281 on: Wed, 29 July 2015, 01:30:38 »
Announcement tomorrow morning.
#hypeisreal
Offline radio_killah
  • Chinchillin'
« Reply #282 on: Wed, 29 July 2015, 01:32:50 »
#hypeisreal
LETSSSSSSSSSSS GO  :-*
Offline azhdar
Re: Project Zealio - Announcement in 9ish hours.
« Reply #283 on: Wed, 29 July 2015, 01:38:17 »
ohhhhhhhhhhhhhhhhh
Offline Zeal
  • * Moderator
Re: Project Zealio - 62g Purple "MX Clear" Switch in transparent housing
« Reply #284 on: Wed, 29 July 2015, 11:02:12 »
You asked for it, we delivered.
Introducing Project Zealios - 62g gold plated springs in an exclusive custom made Purple "MX Clear" stem. No ErgoBrown Gateron bull**** (cough). This is the real deal. Along with the project was a custom made transparent switch bottom housing to maximize LED lighting. Switch will be compatible with 4-pin RGB LEDs (not pictured). The purple stems have the tight stem cross removed from the original MX Clear stems. No more accidental switch breaking! Yay!
« Last Edit: Wed, 29 July 2015, 11:35:45 by Zeal »
« Reply #285 on: Wed, 29 July 2015, 11:05:59 »
Wow!
Where is the purchase link??!?
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #286 on: Wed, 29 July 2015, 11:06:20 »
Offline Zeal
  • * Moderator
« Reply #287 on: Wed, 29 July 2015, 11:09:08 »
Wow!
After receiving some samples hopefully next week, I'll be sending a few out to builders/reviewers. After that phase, a GB will be made. :)
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #288 on: Wed, 29 July 2015, 11:09:16 »
Wow!
Yes I need to buy these!
« Reply #289 on: Wed, 29 July 2015, 11:09:38 »
Wow!
:D
I believe you have my address, sir...
« Last Edit: Wed, 29 July 2015, 11:11:56 by jdcarpe »
« Reply #290 on: Wed, 29 July 2015, 11:10:35 »
Wow!
Send me some samples bro??
Offline Zeal
  • * Moderator
« Reply #291 on: Wed, 29 July 2015, 11:15:39 »
Wow!
:D
Wow!
  • Chinchillin'
« Reply #292 on: Wed, 29 July 2015, 11:15:50 »
 :thumb: Beautiful!
Offline Zeal
  • * Moderator
« Reply #293 on: Wed, 29 July 2015, 11:22:58 »
Oh, I also forgot to mention...
These purple stems have the tight stem cross removed from the original MX Clear stems. No more accidental switch breaking!
    • WTB/WTTF Thread
« Reply #294 on: Wed, 29 July 2015, 11:27:20 »
I am gonna need to get a bunch of these for some customs. What is the cost per switch looking like?
Offline aznairjordan
« Reply #295 on: Wed, 29 July 2015, 11:27:31 »
so nice.. will definitely be picking up some for my hubble mira :D
TGR Jane CE|FC660C|Orion V2
GMK Hyperfuse|GMK Olivetti|GMK Red Alert|Soulfree's Teal|GMK Cyan
Offline Invaderevan
« Reply #296 on: Wed, 29 July 2015, 11:31:20 »
yea, I am gonna want to buy ALOT of these
WTTF Ribbits, Ashen V2 MX, Bronins
Offline joey
« Reply #297 on: Wed, 29 July 2015, 11:33:44 »
Ordering some for sure!
Offline DrHubblePhD
  • I am star stuff
« Reply #298 on: Wed, 29 July 2015, 11:36:43 »
Official Mira switch... I think so  :))
But seriously, when you purchase your Mira (which will likely happen over Zeal's site) consider picking up some of these as well!
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #299 on: Wed, 29 July 2015, 11:37:00 »
So,  like,  Zeal,  I need these. I need a lot of these. Just saying.
