Author Topic: Project Zealio - 62g/65g/67g Purple "MX Clear" Switch in transparent housing  (Read 792593 times)
Offline Zeal
  • * Moderator
    • Zeal Generation Inc.
Re: ? (Introducing Project Zealio~)
« Reply #200 on: Wed, 01 April 2015, 12:39:02 »
Offline Dihedral
  • Mostly Harmless
« Reply #201 on: Wed, 01 April 2015, 12:39:58 »
Project Zealio? WAT?
This is, as promised, getting interesting. That spike looks like the pin on the bottom of an MX switch to me, just translucent.
I think I may be right...
Offline Zeal
  • * Moderator
« Reply #202 on: Wed, 01 April 2015, 12:40:52 »
Except mine's better.
Offline Dihedral
  • Mostly Harmless
« Reply #203 on: Wed, 01 April 2015, 12:51:24 »
OK so here's what I think the most recent image is, explained.
95958-0
Offline Zeal
  • * Moderator
« Reply #204 on: Wed, 01 April 2015, 12:53:54 »
Hue.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #205 on: Wed, 01 April 2015, 12:56:11 »
Sorry for not putting them in an image, too much work to do right now
Offline Dihedral
  • Mostly Harmless
« Reply #206 on: Wed, 01 April 2015, 12:57:36 »
Hue.
That looks to me like the 'chunkier' MX pin. It gives us an idea of what angle the shot is taken from, so this is getting good!
Offline Zeal
  • * Moderator
« Reply #207 on: Wed, 01 April 2015, 12:59:26 »
Hue.
I'm afraid your guess is a bit off
Offline joey
« Reply #208 on: Wed, 01 April 2015, 13:41:37 »
Wanted: Someone with awesome Paint skills.
Offline Zeal
  • * Moderator
« Reply #209 on: Wed, 01 April 2015, 13:45:25 »
Is there a need?
Offline njbair
    • nickbair.net
« Reply #210 on: Wed, 01 April 2015, 14:43:51 »
OK well we've got two parts here...
95973-0
My boards:
« Reply #211 on: Wed, 01 April 2015, 14:45:06 »
* jdcarpe gasps
It's a SWITCH! :eek:
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #212 on: Wed, 01 April 2015, 14:45:44 »
Thanks! You did the work I didn't want to XD
Offline Lastpilot
  • Power stance
« Reply #213 on: Wed, 01 April 2015, 14:46:28 »
Not sure if it's the angle but the stem looks longer than usual....and the housing is maybe shorter? Switches specifically for low profile casings?
Offline plegnic
  • Treble Booty. Bass Guitar.
« Reply #214 on: Wed, 01 April 2015, 14:47:30 »
I think it's just that the two chunks of the image aren't lined up perfectly.
Planck MIT layout [MX Clears] (in-progress) | QuickFire Storm TK [MX Brown] | Poker II [MX Blue]
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #215 on: Wed, 01 April 2015, 14:48:04 »
I think the housing is longer, he just moved it so the image was smaller, and it might be the angle for the stem?
Offline Lastpilot
  • Power stance
« Reply #216 on: Wed, 01 April 2015, 14:48:26 »
Ah, duh. Forgot they were disconnected.  :))
Offline njbair
    • nickbair.net
« Reply #217 on: Wed, 01 April 2015, 14:49:03 »
I might have things in the wrong spot so far.
My boards:
Offline plegnic
« Reply #218 on: Wed, 01 April 2015, 14:51:34 »
Before we got pictures of the pins, I was thinking it was just a normal switch with the colors inverted...
Offline FrostyToast
  • Litshoard
« Reply #219 on: Wed, 01 April 2015, 14:51:36 »
"NDA: By opening this bag, you hereby agree not to reveal any info or pictures of Project Zealio!"
**** NDA. PICTURE! BAM!
Quote from: elton5354
Offline njbair
    • nickbair.net
« Reply #220 on: Wed, 01 April 2015, 14:53:03 »
This looks better:
95975-0
My boards:
Offline Lastpilot
  • Power stance
« Reply #221 on: Wed, 01 April 2015, 14:53:13 »
How do I sign up for the Zealio Closed Beta Test?
Offline Zeal
  • * Moderator
« Reply #222 on: Wed, 01 April 2015, 15:04:11 »
It's still in alpha.
Offline Lastpilot
  • Power stance
« Reply #223 on: Wed, 01 April 2015, 15:05:33 »
OHHHH SHETTTT SOME1 ASSMBLE DEES PIXELS NAOOOOO
« Reply #224 on: Wed, 01 April 2015, 15:06:22 »
* HoffmanMyster is still waiting
Offline njbair
    • nickbair.net
« Reply #225 on: Wed, 01 April 2015, 15:14:20 »
My boards:
Offline plegnic
« Reply #226 on: Wed, 01 April 2015, 15:37:01 »
We can probably guess a few pieces:
Offline azhdar
  • Praise the AZERTY god
« Reply #227 on: Wed, 01 April 2015, 15:39:00 »
I don't see how this picture is ever gonna be helpfull, the label are always on the top of the switches, so it will look just like a gateron clear.
Azerty Propagandiste
Offline Zeal
  • * Moderator
« Reply #228 on: Wed, 01 April 2015, 15:42:29 »
:rolleyes:
Offline Lastpilot
  • Power stance
« Reply #229 on: Wed, 01 April 2015, 15:42:34 »
It looks like there is something in that fat middle bottom stem. Probably some kind of lightsaber crystal.
Offline plegnic
« Reply #230 on: Wed, 01 April 2015, 16:06:49 »
A couple pixels off.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #231 on: Wed, 01 April 2015, 16:09:51 »
I think it is a cherry rgb switch still
« Reply #232 on: Wed, 01 April 2015, 16:37:27 »
It does look similar. Maybe the holes in the bottom housing for the LED aren't the same as the Cherry RGB switch.
Gateron RGB switch?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #233 on: Wed, 01 April 2015, 17:04:57 »
Gateron RGB switch?
Thats the most likely answer
Offline exitfire401
  • The Force is Re/\l
« Reply #234 on: Wed, 01 April 2015, 17:07:20 »
inb4 this puzzle is completed and then the other side of the switch is another 100 piece puzzle
Offline Zeal
  • * Moderator
« Reply #235 on: Wed, 01 April 2015, 17:31:41 »
Except Cherry RGB switches are milky white on the bottom...
Offline Cottonsox
« Reply #236 on: Wed, 01 April 2015, 17:32:43 »
omg it's a t shirt!
Re: ? (100 piece puzzle)
« Reply #237 on: Wed, 01 April 2015, 17:38:07 »
Ok, ok, Goat switches with fully trans housings.
Offline slickmamba
« Reply #238 on: Wed, 01 April 2015, 20:43:35 »
Gold leafed clear top/bottom gateron switches to fix the gateron leafs not being protected
Maybe minus the gateron part?  Gf aha close enough ;)
Hi :)
Offline Moralless
« Reply #239 on: Wed, 01 April 2015, 20:47:45 »
Looks like there's a gateron switch in front of whatever project zealio is.
Time to restart the puzzle with a new pic!
Offline Zeal
  • * Moderator
« Reply #240 on: Wed, 01 April 2015, 21:01:42 »
I'll just leave this here
Offline njbair
    • nickbair.net
« Reply #241 on: Wed, 01 April 2015, 21:03:23 »
Sorry folks. I'm at home now and Photoshop doesn't work on my Chromebook.
My boards:
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #242 on: Wed, 01 April 2015, 21:04:33 »
I can do it once my CSGO comp game ends
« Reply #243 on: Wed, 01 April 2015, 21:05:01 »
So gold leaf Gateron Clear.  Too much hype for that reveal.
Offline Zeal
  • * Moderator
« Reply #244 on: Wed, 01 April 2015, 21:06:08 »
I don't think you see it. :P
Offline Zeal
  • * Moderator
« Reply #245 on: Wed, 01 April 2015, 21:16:17 »
Underskirt shot. :))
[NSFW]
Would be funny if all of this was a cruel April 1st joke...
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #246 on: Wed, 01 April 2015, 21:20:48 »
All of the image that you need to know
Offline Alex92
« Reply #247 on: Wed, 01 April 2015, 21:28:28 »
Aww man...and I just finished it too  :p
Offline njbair
    • nickbair.net
« Reply #248 on: Wed, 01 April 2015, 21:32:28 »
[NSFW]
I definitely see LED holes there.
My boards:
« Reply #249 on: Wed, 01 April 2015, 21:32:45 »
Outside of the fact that it looks to have a gold spring inside with gold contacts, I'm not getting the hype...unless there's an SMD LED module in the post in the middle.
Soooooo
