Author Topic: Project Zealio - 62g/65g/67g Purple "MX Clear" Switch in transparent housing  (Read 789792 times)
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: ? (100 piece puzzle)
« Reply #100 on: Sat, 21 March 2015, 00:45:21 »
Still just seeing a Gateron Clear with a clear or semi-trans cap:
Yeah, that looks like a switch stem. Unless they are Cherry RGB switches with clears. I CRACKED IT!
I'm going with Cherry RGB switches in Red.
I have no interest in Cherry RGB switches.
Then I guess it has to be Gaterons with clear tops, even though he said he wouldn't be hyping Gateron's like this
Offline Lastpilot
  • Power stance
« Reply #101 on: Sat, 21 March 2015, 00:47:59 »
Offline FoC_Tow
  • Brokehlicious
« Reply #102 on: Sat, 21 March 2015, 08:53:50 »
it's probably a cat
or a picture of a cat
holy****, karura's avatar is inside the box!
I am now inside the box.
So Karura, are you dead or alive in that box? Zeal's Cat...
She's both according to the Schroedinger's cat theory I guess...
Day 5:
dug around in your source code
*to be fair idk what a source code even is
That similarity is pretty crazy... Triangle confirmed!  :)
Offline Zeal
  • * Moderator
    • Zeal Generation Inc.
« Reply #103 on: Sat, 21 March 2015, 15:48:14 »
Day 6:
« Reply #104 on: Sat, 21 March 2015, 16:00:45 »
Zeal stickers or business cards?
Offline justify
  • Great news!
« Reply #105 on: Sat, 21 March 2015, 16:11:18 »
Im gonna guess Zeal is making his own type of switch. Gateron tops or anything like that isnt worth the hype that this is building, so I think that zeal is trying to make his own.
Offline njbair
    • nickbair.net
« Reply #106 on: Sun, 22 March 2015, 06:58:39 »
Almost looks Alps-ish to me.
My boards:
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #107 on: Sun, 22 March 2015, 08:04:19 »
It is most definitely a cherry-compatible switch
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #108 on: Sun, 22 March 2015, 08:36:10 »
Kinda looking like a matias switch
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #109 on: Sun, 22 March 2015, 08:54:46 »
Thats what I was thinking at first, but if you look at the stem you can see that it has the 90 degree angle that cherry stems have
Offline FoC_Tow
  • Brokehlicious
« Reply #110 on: Sun, 22 March 2015, 09:38:28 »
Idk if its just me, but I really can't envision a cherry style switch in that picture so far to be perfectly honest.
I get how people see the lower part as a LED tho, since it looks kinda translucent with what might cathode and anode inside...
So assuming it does look mx compatible switch like, and I'm just the only one who fails to visualize that xD,
couldn't it also be a pcb mounted 'cherry style' stabilizer? (except for maybe the LED)
Since some people guessed Zeal is making his own switches, (which to me seems even harder then designing stabilizers)
the options for stabilizers seem to be significantly less then for mx switches, (and costar and cherry both seem to have their issues)
and the fact that Zeal has a history with his gold plated stabilizers, it doesn't seem too far fetched maybe.
I don't really believe thats what it is tbh, but it would fit the mx compatible stem analogy...
And it would definitely be awesome to see a stabilizer that manages to combine crisp non-mushy feel and easy of changing caps I guess!  =)
« Reply #111 on: Sun, 22 March 2015, 11:48:09 »
Zeal is hyping for an MX activated dildo.
« Reply #112 on: Sun, 22 March 2015, 12:43:28 »
At least Halverson will not be disappointed.
Offline njbair
    • nickbair.net
« Reply #113 on: Sun, 22 March 2015, 13:10:27 »
I agree. I think the "90 degree" tab might actually not be a shadow from a cherry cross stem, but a dark spot shining through the hollow center of a Matias stem.
My boards:
« Reply #114 on: Sun, 22 March 2015, 13:20:53 »
The picture so far is definitely not an Alps switch, not unless Matias changed their looks radically recently.  Given the red in the original picture, there is a chance that the picture so far is just unveiling old switches (Gateron Clears) and the new switches, Matias linear switches (which have red stems), will be unveiled later.
Offline njbair
    • nickbair.net
« Reply #115 on: Sun, 22 March 2015, 13:26:48 »
I can't even figure out where the picture so far fits into the pixelated image in the OP.
My boards:
Offline Zeal
  • * Moderator
« Reply #116 on: Sun, 22 March 2015, 16:10:16 »
Day 7:
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #117 on: Sun, 22 March 2015, 16:19:16 »
Offline slickmamba
« Reply #118 on: Sun, 22 March 2015, 20:17:51 »
offering lubed switches with gold springs, duh
Hi :)
Offline taylordcraig
« Reply #119 on: Sun, 22 March 2015, 20:20:59 »
My bet is on a giant trans MX compatible dong.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #120 on: Sun, 22 March 2015, 20:25:43 »
A MX switch that finaly mimics the feel of Topre ? O.O.... Plz
« Reply #121 on: Sun, 22 March 2015, 20:35:52 »
Isn't that what the novatouch is for?
Offline Bromono
  • Wanabe Cicerone
« Reply #122 on: Sun, 22 March 2015, 20:40:25 »
I want the reverse though. :( so I can use those beautiful Korean boards but with the great feeling of Topre.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #123 on: Sun, 22 March 2015, 20:45:44 »
That would be the day  ;D
« Reply #124 on: Sun, 22 March 2015, 20:47:22 »
I guess you'd have me half converted to cup rubber that way.
My bet is still on a giant MX compatible dong.
Offline whentheclouds
« Reply #125 on: Sun, 22 March 2015, 20:51:00 »
mass produced MX-compatible Topre switches would definitely be one of the great milestones in keyboarding history. i wonder if HHKB and Leopold are ready for when that day comes
Offline Dihedral
  • Mostly Harmless
« Reply #126 on: Mon, 23 March 2015, 06:33:25 »
The only new switch type that GH would be more excited for than legit cherry 62g ergo clears.
« Reply #127 on: Mon, 23 March 2015, 07:15:22 »
Your asking for a round peg to be put in a square hole, topre switches (I hesitate to call them switches as they aren't discrete switches like mx switches are) by design are entirely different than mx switches.
I think if there truly was a market for ergo clears cherry would make them, it's all mostly hype.
Offline njbair
    • nickbair.net
« Reply #128 on: Mon, 23 March 2015, 09:17:48 »
The two are fundamentally different, but there's really no reason you couldn't put a single rubber dome, spring, and capacitive pad inside a discrete switch casing.
My boards:
Offline Sygaldry
  • Edema Ruh
« Reply #129 on: Mon, 23 March 2015, 09:56:41 »
Digilog bro!
null
Offline Zeal
  • * Moderator
« Reply #130 on: Mon, 23 March 2015, 17:46:17 »
Day 8:
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #131 on: Mon, 23 March 2015, 18:22:38 »
Offline Cottonsox
« Reply #132 on: Mon, 23 March 2015, 18:34:08 »
Gateron Stabs! In Semi Clear/Clear that they use in there switches.
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #133 on: Mon, 23 March 2015, 18:35:38 »
Gateron ALPs switches
« Reply #134 on: Mon, 23 March 2015, 18:40:57 »
Ok, ok, Goat switches with fully trans housings.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #135 on: Mon, 23 March 2015, 21:39:25 »
I just want to say thanks to the people who are putting the pieces together and posting it.
I still have no idea what it is, all i'm seeing is a switch cause that's what everyone is saying XD
GON NerD TKL DTA Edition
« Reply #136 on: Mon, 23 March 2015, 22:09:05 »
Offline joey
« Reply #137 on: Tue, 24 March 2015, 02:36:10 »
I hope it's this!
Offline Dihedral
  • Mostly Harmless
« Reply #138 on: Tue, 24 March 2015, 02:55:07 »
I would buy them in a heartbeat. I think there would be a market as a matias quiet click style 'ergo switch'
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #139 on: Tue, 24 March 2015, 10:28:28 »
Of course! how did i not see that till now....
Offline Zeal
  • * Moderator
« Reply #140 on: Tue, 24 March 2015, 18:44:46 »
Day 9:
Offline njbair
    • nickbair.net
« Reply #141 on: Tue, 24 March 2015, 18:49:19 »
Ohhh pwnnarwhal, we need your MS Paint skillz.
My boards:
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #142 on: Tue, 24 March 2015, 18:54:50 »
You can't get these skills through MS Paint, photoshop is the only way you get the skillz
Offline Zeal
  • * Moderator
« Reply #143 on: Tue, 24 March 2015, 18:56:28 »
But your Day 7 slice is misaligned by a couple pixels. :(
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #144 on: Tue, 24 March 2015, 18:57:57 »
Thats because I am using Gyazo to screenshot the photoshop canvas.
Offline Bromono
  • Wanabe Cicerone
« Reply #145 on: Tue, 24 March 2015, 19:05:11 »
Definetly a switch of some kind... Maybe it could be pre-ensembled ergo clears?
Offline njbair
    • nickbair.net
« Reply #146 on: Tue, 24 March 2015, 19:06:47 »
At least he's trying to help!!!
My boards:
Offline Zeal
  • * Moderator
« Reply #147 on: Wed, 25 March 2015, 11:53:56 »
Day 10:
Offline FoC_Tow
  • Brokehlicious
« Reply #148 on: Wed, 25 March 2015, 15:09:45 »
Hope you guy don't mind!
Edit: Increased the size and fixed a few issues   :)
« Last Edit: Wed, 25 March 2015, 15:20:35 by FoC_Tow »
Offline njbair
    • nickbair.net
« Reply #149 on: Wed, 25 March 2015, 16:23:47 »
I still can't tell where in the pixelated swirly image in OP this is supposed to be.
My boards:
