Author Topic: Project Zealio - 62g/65g/67g Purple "MX Clear" Switch in transparent housing  (Read 785267 times)
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: Project Zealio - 62g Purple "MX Clear" Switch in transparent housing
« Reply #300 on: Wed, 29 July 2015, 11:40:23 »
So,  like,  Zeal,  I need these. I need a lot of these. Just saying.
This goes too well with your avatar, mane...
Offline FrostyToast
  • Litshoard
« Reply #301 on: Wed, 29 July 2015, 11:40:53 »
Maximum overhype.
Quote from: elton5354
Offline jbondeson
Welp, no more switch buying for a while.
What kind of manufacturing timeframe are we talking?
hm... send some? curious :)
Offline DrHubblePhD
  • I am star stuff
« Reply #304 on: Wed, 29 July 2015, 11:44:06 »
Maximum overhype.
It looks like its time to produce the ****loard
Offline Zeal
  • * Moderator
    • Zeal Generation Inc.
« Reply #305 on: Wed, 29 July 2015, 11:44:59 »
I need lots. too.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #306 on: Wed, 29 July 2015, 11:45:05 »
That's my asking politely face. :))  :-*
Offline Zeal
  • * Moderator
« Reply #307 on: Wed, 29 July 2015, 11:46:01 »
It shouldn't be too long. I'm going to guess under a month, but will confirm before GB.
Offline cwils0n
  • twiggletwaggle
« Reply #308 on: Wed, 29 July 2015, 11:48:04 »
I wants them.
Offline jbondeson
I will prepare my wallet!
I foresee several of my keyboards going under the soldering iron later this year. :)
Offline Lastpilot
  • Power stance
« Reply #310 on: Wed, 29 July 2015, 11:54:54 »
Looks perfect, I'm in for sure. :thumb:
Offline aznairjordan
You asked for it, we delivered.
Introducing Project Zealios - 62g gold plated springs in an exclusive custom made Purple "MX Clear" stem. No ErgoBrown Gateron bull**** (cough). This is the real deal. Along with the project was a custom made transparent switch bottom housing to maximize LED lighting. Switch will be compatible with 4-pin RGB LEDs (not pictured).
so nice.. will definitely be picking up some for my hubble mira :D
Official Mira switch... I think so  :))
But seriously, when you purchase your Mira (which will likely happen over Zeal's site) consider picking up some of these as well!
Noob question time, will the mira pcb support the rgb leds that zeal is talking about?
TGR Jane CE|FC660C|Orion V2
GMK Hyperfuse|GMK Olivetti|GMK Red Alert|Soulfree's Teal|GMK Cyan
Offline radio_killah
  • Chinchillin'
Nope it doesnt not. They are not the same thing. Mira will only support the usual single color 2 pin LED's the ones Zeal is talking about are full color range 4 pin LEDs.
hmm okay, guess I gotta get these sip socketed then. Thanks for the info!
Offline admiralvorian
  • DIY
« Reply #314 on: Wed, 29 July 2015, 12:21:38 »
Zeal this is some next-level **** man
Darude Status:
☐ Not Sandstorm
☑ Sandstorm                                               wts wtt wtb
Offline livingspeedbump
    • KeyChatter
« Reply #315 on: Wed, 29 July 2015, 12:22:15 »
Well done!
I see many, many of these in my future  :thumb:
<- My Collection (so far)
Offline Booper
    • omniclectic.com
« Reply #316 on: Wed, 29 July 2015, 12:23:00 »
Holy crap those are super sexy. I'm in for sure!
boop!
    • KeyChatter
Re: ?
« Reply #317 on: Wed, 29 July 2015, 12:24:31 »
#hypetrainisapparentlytooreal
Totally going to stick these in the Mira.
The hype of these+mira may finally do me in.
Offline Zeal
  • * Moderator
« Reply #318 on: Wed, 29 July 2015, 12:32:09 »
Boop's purple seal of approval? ;)
Well done!
I do too. So glad that the dream is finally becoming a reality!
Thanks! :)
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #319 on: Wed, 29 July 2015, 12:32:31 »
I'm more of a linear guy, but these would look GREAT in the ALT 60!!!
Offline Zeal
  • * Moderator
« Reply #320 on: Wed, 29 July 2015, 12:33:27 »
Linear 62g variant will be the "clear" stem shown on April 1st... :) Both switches will be available during the pre-order/GB!
« Reply #321 on: Wed, 29 July 2015, 12:34:18 »
Or a JD45, really. Just because the PCB is red means nothing! :))
Zeal I need these for my Pink 456!
That is when (if :( ) it arrives.
Offline Zeal
  • * Moderator
« Reply #323 on: Wed, 29 July 2015, 12:44:24 »
:( I hope your 456 is found promptly and undamaged.
Offline Lurch
« Reply #324 on: Wed, 29 July 2015, 12:44:26 »
REH-HEH-HHEEEAAALLLLLYYYY?
I will definitely be grabbling some of these.
Nice one Zeal. :thumb:
Quote from: Flyersfan1
Offline Zeal
  • * Moderator
« Reply #325 on: Wed, 29 July 2015, 12:46:11 »
Someone needs to find a way to make transparent PCBs w/o the yellow tint from fiberglass.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #326 on: Wed, 29 July 2015, 12:46:47 »
it would probably be very expensive, but you could do glass.
USPS started being very helpful once I dropped the 1k insurance bomb. The board is boxed with 4-5in of foam on every side so I'm fairly sure that it'll be well protected.
Seriously though, I'm putting these switches in the board. They'll look great with the pink.
Offline byker
  • Literally Canada
« Reply #328 on: Wed, 29 July 2015, 12:53:55 »
Hmm, I do like purple. I guess I'm in for some.  :-*
« Reply #329 on: Wed, 29 July 2015, 13:00:52 »
I remember seeing a glass PCB somewhere with moderately transparent traces so light could shine through. IIRC it was on some eng field trip 2ish years ago.
« Last Edit: Wed, 29 July 2015, 13:03:30 by Joey Quinn »
Offline Blackhawk
« Reply #330 on: Wed, 29 July 2015, 13:03:07 »
Ergo clears with purple stems?! Count me in  ;D
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #331 on: Wed, 29 July 2015, 13:08:57 »
GJ Zealios, knocked it right out the park!
Offline VinnyCordeiro
« Reply #332 on: Wed, 29 July 2015, 13:38:21 »
Dang it, now I'll be forced to add support for RGB LEDs on the AUNK... And buy tons of these switches as well.
Offline Zeal
  • * Moderator
« Reply #333 on: Wed, 29 July 2015, 13:41:57 »
+1 for more RGB aftermarket PCB designs. :) I'm also in the works with a PCB designer to support 4 pin RGB LEDs.
Offline njbair
    • nickbair.net
« Reply #334 on: Wed, 29 July 2015, 13:52:41 »
These are made for Hyperfuse. On a white plasti-dipped Leeku 1800 PCB with cyan LEDs. In a gray case.
My boards:
« Reply #335 on: Wed, 29 July 2015, 14:31:31 »
Whelp. Found the new switches I'll be using on my first custom.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #336 on: Wed, 29 July 2015, 14:43:53 »
*unzips.....*
I need lots of these :D Guess my (brief) self imposed GB ban will be over (again)!
« Reply #337 on: Wed, 29 July 2015, 14:47:41 »
*unzips.....*
I hear you. I'm not really buying keyboard stuff anymore, and I have to have these. Many. Many of these.
« Reply #338 on: Wed, 29 July 2015, 14:52:28 »
*unzips.....*
I'm not even using MX boards anymore and I'm thinking about buying some.
« Reply #339 on: Wed, 29 July 2015, 14:55:29 »
*unzips.....*
I'm using two Dell SK-8115's. One at home, one at work. I win. :))
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #340 on: Wed, 29 July 2015, 14:57:05 »
I really hope you're joking...not cool.....not cool.
« Reply #341 on: Wed, 29 July 2015, 14:59:38 »
Not joking, actually. :)
Dell SK-8115. One at home, one at work. Pretty darn good for a rubber dome over membrane. I disassembled one for painting, and learned why I like these Dells. Slider (attached to keycap) in a channel over the rubber dome sheet. Under the domes are a pair of membranes, very much like what are in an IBM Model M.
I painted the one I use at home white. Now I just need to swap those green LEDs for blue ones.
Made new Dell thread here, so we don't derail Zeal's thread any more.
« Last Edit: Wed, 29 July 2015, 15:16:07 by jdcarpe »
« Reply #342 on: Wed, 29 July 2015, 15:00:53 »
Congrats to JD on 11K posts  :thumb:
Maybe I'll dust this off and use it. (It's very tactile)
« Last Edit: Wed, 29 July 2015, 15:08:05 by SpAmRaY »
Offline chromatically
« Reply #343 on: Wed, 29 July 2015, 15:03:01 »
more purple.... please, my wallet can't handle this :(
« Reply #344 on: Wed, 29 July 2015, 15:03:21 »
I used to have that keyboard at work and I loved it! I didn't even know it was a really good rubberdome; I just loved using it.
Edit:
Yes! The IT guy still had a couple left. Gonna give back the ****ty wireless Logitech.
106832-0
« Last Edit: Wed, 29 July 2015, 15:09:45 by romevi »
Offline digi
  • elite af tbh
« Reply #345 on: Wed, 29 July 2015, 15:07:55 »
« Reply #346 on: Wed, 29 July 2015, 15:07:57 »
It seems that these tick all the boxes, including some boxes that didn't exist!
Are they going to be generally available for purchase after the GB?
Offline monotagary
  • Keycaps > Rent
« Reply #347 on: Wed, 29 July 2015, 15:14:16 »
This is incredible Zeal! The hype for this is real.
Offline Noko
  • jolonarr: a tough dude who takes no esses!
    • Noko's Leatherworks
« Reply #348 on: Wed, 29 July 2015, 15:26:45 »
Zeal, you are amazing.  Holy amazeballs.
Right down to the purple.  !!!!
Noko's Leatherworks - Handmade Custom Leather Wrist Rests -  http://www.noko.ca
Sales Thread: http://geekhack.org/index.php?topic=51762.0
Build Log: http://geekhack.org/index.php?topic=47704.0
Offline mbrown559
« Reply #349 on: Wed, 29 July 2015, 15:28:58 »
Yes, I need these switches in my life.  Will be ordering a good amount of these when they are available.
