Author Topic: Modding SDLto 9Pin D-Sub  (Read 2630 times)
Offline InSanCen
« on: Mon, 31 August 2009, 11:08:08 »
Ok, I'm sick of losing cables to my cat munching them (He's an idiot, loveable, but really stupid).
So... I am going to take my 1391406 in the worst condition, and whack it on a removable 9Pin D-Sub so that it is still removable. Why 9 Pin? It looks about the right size, is commonly available, and will be so for the forseeable future.
I have 9 pin sockets and plugs, PS/2 6 pin Mini Din and some Cat5 cable (In a colour-coded Purple, my missus would be proud!). Pinouts have been sourced at http://www.tavi.co.uk/ps2pages/ohland/keyboard.html#SDL_PS2.
Anything I should know before I attack this with a Soldering iron and Dremel?
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline InSanCen
« Reply #1 on: Mon, 31 August 2009, 12:28:29 »
SDL connector came out just fine (Soldamop rules!).
D-Sub is connected to the cable at the KB end. Just need to attach it at the PS/2 end, and internally in the KB.
The D-Sub's "Wings" and the SDL's are identical, so with a bit Hot Glue (Temporary), it'll sit in there just great methinks.
I did consider USB, but other people do occasionally use this PC, and I just know it'll get jammed straight into a USB port, despite it not making sense to do so...
Offline sggsix
« Reply #2 on: Mon, 31 August 2009, 12:51:45 »
Luckily he never developed a taste for Topre cables or I'd have to shoot him.
Lmfao, my cat does the same thing..........  But his diet consists of the wires with cloth on them like steel series products have.
HHKB Pro 2  (black)
Realforce 101 (white)
Unicomp Spacesaver Model M Russian Key Caps (pearl)
HHKB Lite 2 Japanese Key Caps (black)
HHKB Lite English Key Caps (white)
Offline Mercen_505
« Reply #3 on: Mon, 31 August 2009, 12:58:49 »
My cat is exceedingly smart: he only targets the most expensive objects in the house.
Offline InSanCen
« Reply #4 on: Mon, 31 August 2009, 13:15:52 »
Quote from: ripster;113429
Actually, the USB Mod I linked DOES make it a fully USB keyboard.  Not worth the effort unless you have a keyboard you really want to protect.
Like your Wang.  Your cat doesn't nibble on your Wang does he?  (somebody make me stop......)
No, the **** does not nibble on the Wang... :Cry:
Apparently, IBM's not only type better, but taste better too!
Will get it finished later tonight, when the GF and Duaghter are in bed... the Daughter is currently "Helping" me by running away with my Screwdrivers...
Offline sggsix
« Reply #5 on: Mon, 31 August 2009, 13:17:38 »
Quote from: insancen;113433
no, the **** does not nibble on the wang... :cry:
Apparently, ibm's not only type better, but taste better too!
Will get it finished later tonight, when the gf and duaghter are in bed... The daughter is currently "helping" me by running away with my screwdrivers...
lmfao!!!
HHKB Pro 2  (black)
Offline rdjack21
« Reply #6 on: Mon, 31 August 2009, 13:32:16 »
Quote from: InSanCen;113433
Oh running away with a screwdriver is not to bad a pain yes. Try taking apart a HHKB Pro with the kids around. My daughter ran off with one of the domes and my son just loved those little conical springs.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline rdh
« Reply #7 on: Mon, 31 August 2009, 18:06:23 »
Quote from: InSanCen;113362
Pet stores sell bitter tasting stuff you can put on your cables and such, which might eventually discourage him.
at home: IBM "Space Saving" Model M
at work: Topre Realforce 87UKB55
Offline talis
« Reply #8 on: Mon, 31 August 2009, 18:30:33 »
Quote from: rdh;113494
If the weak stuff the pet store sells doesn't work, see if you can get your hands (well gloved hands) on some pure bitrex.  That is almost guaranteed to do the trick.
Offline talis
« Reply #9 on: Mon, 31 August 2009, 19:03:01 »
It seems like another possible solution, if it continues to be a problem is to just put a RJ-45 jack on the keyboard end, and one right down near the PS/2 jack.  That way you can use a standard off the shelf network cable between them.  Easy to replace, and cheap to buy anywhere.
Offline InSanCen
« Reply #10 on: Mon, 31 August 2009, 19:17:23 »
Quote from: talis;113512
If I'm going to Cut 'n' Shut the cable, I might as well replace the SDL socket. It's going be a pig to find cables for it one day (Long before the keyboard itself wears out), and this just seems a lot easier somehow.
Besides, I'm done... well, sort of.
All soldered up, but I need to pop some support holes in there to hold the keyboard side of it in. This involves a Dremel. I won't be doing that at 1:15AM unless I fancy Amateur castration from her Ladyship.
As for the Jaffa the cat. If I see the little sod doing it, he'll get properly shouted at. Can't really do more than that though, Kinda like him too much. They do learn eventually, he won't walk on top of my PC's case now, ever since I took the fan guard from the top mounted 80mm Delta Screamer. The vet's bill that followed this lesson wasn't so nice though.
I like the cable sleeving idea. I may just braid it if he goes through this stuff (Solid Core CAT5. My KB doesn't move much), and see if that puts him of.
Offline InSanCen
« Reply #11 on: Mon, 31 August 2009, 19:43:08 »
Quote from: ripster;113518
Ouch.
Japanese subway sign:
Yup, pretty much. He has a little bald bit on the end of his tail now.
Here's what I think is the correct pinout of the controller PCB, as Viewed from above. If you think any different, Yell at me (please do, or I may let the magic smoke out!)
Parts list for those in the UK.
Cable (VB20) *Any 4 core will do nicely, I used this as it was lying round, and a funky colour*
http://www.maplin.co.uk/module.aspx?moduleno=19868
PS/2 Plug (JX04)
http://www.maplin.co.uk/module.aspx?moduleno=1110
9 D-sub socket (RK61) & 9 D-sub plug (RK60)
http://www.maplin.co.uk/module.aspx?moduleno=1113
9 D-sub Metal Hood (CT71)
http://www.maplin.co.uk/module.aspx?moduleno=12059
Numbers in () are Maplin Order codes (Yeah, I work there, give the staff a break, write the order codes down).
« Last Edit: Mon, 31 August 2009, 19:51:03 by InSanCen »
Offline InSanCen
« Reply #12 on: Mon, 31 August 2009, 20:17:04 »
Quote from: ripster;113526
Yep - bottom of your diagram corresponds to bottom edge of keyboard.  Check to make sure the 5V line isn't shorted with a multimeter before plugging in and you should be fine.
Good Good... Nothng is shorted (Visual check, my Multimeter seems to be stuffed, new toy tomorrow methinks)
LOL - this sounds promising:
I had it left over from a 2,500 seat cabling job I did. Great cable, cost a bloody fortune back then. Only thing that met the Regs though... and Purple is a great colour for a Keyboard cable!
Offline InSanCen
« Reply #13 on: Tue, 01 September 2009, 04:55:49 »
Well, somethings not right with it.
I did end up having to mes3s the case around quite a bit, so mabye I've knocked something out.
Will look at it in a bit.
Oh, and while I was messing around trying to recess the D-Sub, I decide3d some drainage channels were in order, judging by the gunk pooled in the bottom of it.
Offline InSanCen
« Reply #14 on: Fri, 04 September 2009, 17:40:53 »
It Lives!
My soldering is **** (Shaky hands... think Parkinson's and you're there). Dry joint had pulled off under flex.
Re-did the lot with decent (Lead, fluxed) Solder, and it's as good as I'll get it.
Had to semi-permanently attach the cable though. The standard D-dub screws that lock the 2 parts together won't reach through the thick plastic, so I enlarged the holes on the female connector (not on the KB), and put M3 nuts and bolts through it. Still removable... to a Point. I need to think another way to rework it. Maybe USB after all.
