Author Topic: Omnikey 101 with correct Ctrl/Caps Lock keycaps  (Read 2784 times)
Offline jacobolus
« on: Fri, 06 March 2015, 23:25:15 »
http://www.ebay.com/itm/331498817388
From what I understand these originally came with 2 sets of ctrl/caps lock caps, and maybe had a dipswitch setting to swap the functions of the keys? Anyway, on used boards you usually don’t get any extra caps, and 1.75u home row Tai Hao doubleshot ctrl keycaps are pretty hard to find.
Also, $50 + shipping is a great price.
Looks like the A switch needs to be replaced, but many potential buyers probably want to replace all the rest of the switches anyway, so...
Offline drewba
Re: Omnikey 101 with correct Ctrl/Caps Lock keycaps
« Reply #1 on: Sat, 07 March 2015, 01:00:45 »
Aaaaand sold. That was quick!
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Sat, 07 March 2015, 04:37:41 »
Well it says the A key doesn't click, nit that it doesn't work. Reclicking Alps can be done by just bending the leaf spring outwards a little - that's how I reclicked my 5162, works a treat. Nice price though, not surprised people dove on it :P .
« Reply #3 on: Sat, 07 March 2015, 08:12:23 »
There are a couple more in less nice condition for a little bit more money that have been languishing for a couple of weeks.
A year or 2 ago, many weeks would go by between seeing one of these listed.
- Bill Roberts 2026-06-17
« Reply #4 on: Sat, 07 March 2015, 20:09:22 »
From what I understand these originally came with 2 sets of ctrl/caps lock caps, and maybe had a dipswitch setting to swap the functions of the keys? Anyway, on used boards you usually don�t get any extra caps, and 1.75u home row Tai Hao doubleshot ctrl keycaps are pretty hard to find.
afaik it either depends on the northgate in question and some of them came with dvorak caps and capability (5k177 / djdmatic had some NOS a few years back) This indicates that they could either be ordered with different kinds of functionality and keycaps.
Anyway, this was a great find.
Offline possumgumbo
« Reply #5 on: Mon, 09 March 2015, 18:36:55 »
I just got a gold label OmniKey/102 from a friend's demolition site. I can't seem to get the keycaps off, but they click incredibly loudly. Is that proof that it's the blue one?
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Mon, 09 March 2015, 18:38:59 »
Most gold labels are, from what I've heard. Would be amazing though, just about my dream keyboard that is :D .
Offline jacobolus
« Reply #7 on: Mon, 09 March 2015, 18:48:13 »
White Alps actually clicks louder than blue Alps. I recommend using a pair of butter knives to pull a cap off. Just slide the blades under opposite sides of the keycap and gently pry upward.
Offline Special K
« Reply #8 on: Tue, 10 March 2015, 09:21:29 »
Invest in a keycap puller (or 2, for the larger keys):
http://www.amazon.com/Mechanical-Keyboards-Inc-Keycap-Puller/dp/B00M9ETHYU/ref=sr_1_2?ie=UTF8&qid=1425997196&sr=8-2&keywords=keycap+puller
If you end up spending any reasonable amount of time on GH you will likely need these sooner or later.
Also I have a keyboard with blue alps and the click is fairly soft, so I'm not sure what type of switch you have.  I think my MX blues even click louder than my blue alps.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
IBM Model M 1391401 - 11/13/87
Quote from: ripster
LOL - we're on post #163 of this mega-thread and you've gone from"keyboard n00b" to "keyboard sn0b".  We've done our job.
Offline E TwentyNine
    • Some of My Keyboards
Offline possumgumbo
« Reply #10 on: Tue, 10 March 2015, 10:48:31 »
Is this an acceptable puller? I simply must use my Prime.
I now own a TECK 209 (Brown), an Omni Key/102 Gold, and a partially assembled home 3D printed keyboard I designed (MX Blue with a Brown spacebar), so I definitely need a key puller soon.
http://amzn.com/B00SZAG2CW
