Author Topic: DIY Metal Key Caps  (Read 34342 times)
Offline BlindShadow
DIY Metal Key Caps
« on: Fri, 06 March 2015, 23:48:26 »
So i tried making some metal key caps out of Sn - tin
http://imgur.com/9pkj7ni
I ran into some problems with metal flow rate and detail retention, so i figured i would ask if anyone successfully have made metal key caps before ?
if so then what material did you use or what technique did you use ?
Currently i am considering changing the key cap design to better accommodate the material, any suggestions ?
Re: DIY Metal Key Caps
« Reply #1 on: Fri, 06 March 2015, 23:50:39 »
I've made some with zinc by sand casting.  Unless you're using a nice metal mold and have a nice foundry, you're going to run into issues.  Figuring out how to do the stem is the hard part.
« Last Edit: Fri, 06 March 2015, 23:52:13 by nubbinator »
Offline DrHubblePhD
  • I am star stuff
« Reply #2 on: Sat, 07 March 2015, 00:19:28 »
Yeah another possible solution is to use a low melting point metal to first cast a negative, you can find billets on Amazon. Then take the negative and use it to cast a mold out of something more heat resistant  :thumb:
Offline BlindShadow
« Reply #3 on: Sat, 07 March 2015, 12:19:41 »
nubbinator : That's a really nice set of keycaps, did you do the zinc at home ? and what did you use for the stem zinc also ?
DrHubblePhD : Sounds interesting with the billets, i might try that
I wonder, do any of you know if this LEGO part fits on a cherry MX switch stem ?
http://imgur.com/5saobcv
Would be an easy glew on fixtiure, instead of making the key cap stem part of the mold which is tricky.
I am trying ABS molding later today might give some okay results ^^
« Last Edit: Sat, 07 March 2015, 12:25:44 by BlindShadow »
Offline Asininity
« Reply #4 on: Sat, 07 March 2015, 18:23:14 »
I have some technic stuff at home. I'll look whenever I get home and let you know!
Offline sirisaac1982
  • The Answer is 42...
« Reply #5 on: Sat, 07 March 2015, 20:27:30 »
This is cool.
I've always wanted to make my own ingots.  :thumb:
Offline Fusion
  • Unknown Lurker
« Reply #6 on: Sun, 08 March 2015, 00:29:46 »
I just tried - the piece does fit bit it's slightly too loose. Might need to stuff it or glue it on or something.
Edit for science:
« Last Edit: Sun, 08 March 2015, 00:50:16 by Fusion »
Offline Asininity
« Reply #7 on: Sun, 08 March 2015, 18:13:00 »
Edit for science:
It's a shame that it doesn't work.
It's so close!
Offline Vaurien
  • don't love jank, jank loves me
« Reply #8 on: Sat, 22 November 2025, 06:25:26 »
hi, fist time poster here, I plan to make a set with ceramic shell casting but I am struggling to understand the gaiting system. do you have a picture of your gating system?
« Reply #9 on: Wed, 28 January 2026, 09:56:11 »
We use aluminum alloy, which is machined in a CNC machining center and then anodized. Doing it by hand would be quite laborious; using a machine would produce much better results.
CNC machining master
